G Body Wheel Size
Can anyone please tell me what the largest reasonable Diameter Wheel size I can mount to a 1983 SC? I have 16" now, can I go to 19"?
Kevin |
Kevin:
I've heard about folks running 18" wheels, but 17" seems to be the sweet spot, as our suspensions were designed to work with a fair bit of tire flex. Key is making sure that the diameter of the tire you're using is comparable to (or maybe even a bit smaller than) the diameter of the stock tires -- otherwise, you're going to lose some power spinning the larger diameter tire Check out the bottom of this thread for some good info http://forums.pelicanparts.com/porsche-911-technical-forum/1093626-911sc-fuchs-changing-6-7-911-7-8-951-a.html |
Thanks Darrin!
It is your car, and feel free to do whatever you want to your car. But 19s on a G body will look silly. There will be basically rubber band sidewalls. It will ride and perform poorly.
![]() I have 17 inch Euromiester wheels 7 & 8 width. and 225/45 front and 255/40s rear. The fill the wheel wells and look great. Again, your car, so do whatever you want, but I suspect you will hate how it handles with 19s and rubber band sidewalls. Good luck.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
a secondary but still very important consideration is the torque cost of the wheel & tire, here it's more the tire, torque cost comes from mass and distance of the mass from the axis of rotation ![]() when choosing tires, the OD is the most significant datum to consider, w/ stock engines and gearing try to keep tire OD under 25"
Pavement Pounder
I just went with 17"s on my setup.
17x8 et30 and 17x9.5 et20 215/45/17 and 245/40/17
What tire specs?
I've run 17s on Both my SCs and Carrera, personally I don't think there is any benefit going 18 or larger.
![]() ![]() ![]() ![]() [img]http://forums.pelicanparts.com/uploads26/302122_10150306382739513_576812_n1621555875.jpg[ ![]() My 81 SC under the process of rebuilding. ![]() ![]() ![]() ![]()
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
When I got my car a few years ago, it had 964 bumpers and 18". I think that is going a bit to far... Here is a pic;
-------- 1977 911s |
I went the 17 bbs and wish I would have kept the 16 fuchs too
Donk, dont
Pavement Pounder
I'm good with tools.
My car at the time of purchase had 16" Fuchs. 7" and 8" with 205/55/16 on the front and 225/50/16 on the rear.
I went to 17" wheels with 7" on the front and 8" on the rear. Front offset is et 23 on the 7" and et 10 on the rear 8". Tires 205/50/17 front and 255/40/17 rear. NO ISSUES !!!!
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
(man/dude)
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Thanks Jonny......
http://forums.pelicanparts.com/porsche-911-technical-forum/1002364-85-outlaw-build-thread.html
Hi @AG81 - are you sitting at European ride height or US? I have an '84 that has been lowered to European ride height sitting on the original 16 in fuchs. I am looking at going to the exact tire and wheel size of your setup (Tires 205/50/17 front and 255/40/17 rear) but not sure if it will fit properly given the European ride height. Thanks!
In '84 all markets had the same spec which was the same a was used from '69 ![]() I'm also curious as why you chose those tire sizes
AG81 - Love your wheels.
'71 914-6 #0372 '17 Macan GTS |
I had 17" tires on my '79 SC when I bought it from the last owner. It looked fine, but the ride was fairly rough on my northern city roads. I also had some rubbing on the rear flares when I had extra weight in the car.
I changed to 16" and the ride comfort improvement was noticeable. Original wheels: ![]() New wheels:
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 06-04-2021 at 07:45 AM.. |
