Originally Posted by Arlo911
Hi Jared, I've had the same thing happen to me. In my case it was a ball from the steering shaft bearing that got intermittently lodged inside the steering shaft housing. But, there are a couple of other things that could cause this behavior, from a worn steering rack, to worn steering joints etc. Best to have someone check it out before you have an accident.
I found some more stuff that might be relevant.
From October of last year:
(There is a parts diagram in the thread and a suggestion of checking #23)
"I had an odd issue with my 77 911S years ago. When I would make hard right turns the steering would lock intermittantly as I softened the turn. A immediate sharper right again would loosen it up. It ended up being a part of column bearing left behind from a previous repair. The individual ball bearing would basically ride up the bearing race and get wedged."
"The smuggler box bearing starts to disintegrate (Rust) over time. The roller bearings come out of the race. The rest of the linkage usually lasts longer. When mine went my mechanic said “ it’s always the lower bearing”."
http://forums.pelicanparts.com/porsche-911-technical-forum/1075183-steering-issue.html
