Why do I keep breaking Tarrett drop links?
Today I was in the middle of a spirited drive on Mulholland. When making a left, I heard a pop. After stopping, I looked under the car to see a broken drop link. I have had 2 '87 3.2s and with both I had Tarret drop links fail. I am familiar with how to set them up so there is no preload, but still this keeps happening.What am I missing? Anyone know a possible cause??
Photos would help, especially a closeup of the break itself.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Same point of failure on two different cars. Co-incidentally both happened on the same stretch of road while cornering.
Racer
You are probably binding the joint and braking it. Have you check that the drop link can move with out binding through out the range of suspension travel?
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Racer
As the suspension moves up and down, the drop links move and the rose (heim) joints move to compensate. If the rose joints bind, something has to give......
Looks like you have them upside down
Racer
That piece that the red arrow points to is for the spring plate, not the control arm.......and that rose joint the red arrow points to has severely limited movement because you mounted it wrong....you need misalignment spacers on each side of the rose joint.
"The Tarett adjustable drop link we are using has the ability to be attached to the swing arm or the banana arm. When installing in the swing arm the included eccentric nut/spacer will replace the eccentric nut in the swing arm. This nut is used to set the toe adjustment in the rear suspension. Installing the drop link in the swing arm will give the sway bar a little softer feel. Also, if you install it in the swing arm you should get the alignment checked after installation to insure proper toe in. Follow these steps for adjusting preload after installing in the swing arm." |
Racer
Fine. Do it your way and break stuff...I am done.
Not my way, I'm just quoting Wayne Dempsey. If that's not correct, I would hope that he and Pelican would update their information.
As Winders mentioned, you have it installed incorrectly. Missing the misalignment spacers.
Ball Joint Rod End Washers. You need 8 washers in total in 12mm size.
Winders and Solamar are correct regarding the incorrect setup. https://www.mcmaster.com/rod-end-inserts/
Paul 1987 Carrera coupe Last edited by Ok here we go; 08-23-2021 at 08:47 PM.. |
I will send an email to Tarett and see what they have to say. |
I hope those washers fix your problem. Cheers! Last edited by Ok here we go; 08-23-2021 at 09:17 PM.. |
Racer
As delivered, the Tarett rear bar is meant to be installed with the drop link attached to the spring plate. If you want to attach it to the trailing arm, you need to buy additional hardware. Specifically, what Solmar shows in his photo.
Those washers Will NOT FIX THE PROBLEM!
The spacers worked for me, and I drive mine pretty hard on AX on weekends. If you think the misalignment spacers will solve the problem, then by all means. The McMaster link also has the spacers as an option as well. Solamar's image has both the washer and the spacer. |
It's a 914 ...
If your mechanic is the one who installed it this way, you might want to consider whether he's the right one to work on your car. I don't mean to come across as harsh to him, but the way it's installed in the picture you posted shows a misunderstanding (installing the eccentric bolt as a spacer, causing the binding) of how these parts should work.
