Fuchs Jewelry
Ok, I admit it. I'm OCD when it comes to hardware. I have a new set of Fuchs heading my way and I'm obsessing about the details, specifically the tire stems.
Yes, the good 'ol rubber stems would work fine. But then theirs the issue of stem flex at speed, requiring support tabs, blah, blah, blah, and the further you dig, most recommend metal stems. If you dig deeper, the really cool guys use alloy stems ![]() So, after searching through the major suppliers (Myers Tire Supply, Dill) I found what I wanted, but with a 100 piece minimum... Haltec H-523MS Light Alloy Valve Stem After a bit more Google Fuing I struck gold ![]() https://tiresupplynetwork.com/collections/metal-valve-stems/products/h-523ms-light-alloy-valve-stem No minimum and Free shipping over $25. Yes Please!!! Prepare to feast your eyes - ![]() ![]() ![]() Now if I can just find some decent tire weights
1978 SC Targa Last edited by Solamar; 12-20-2021 at 03:28 PM.. |
(man/dude)
Nice!!!
I always liked the looks of the 949 Racing ones. They come in more jewelry-ish color options, too... Bronze anodized aluminum valve (Edit/PS)- if you find any light alloy tire weights let us know.....
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
It's actually the opposite problem. Now that lead is evil (illegal) the tire weights are crappy zinc. I've decided I'm not going to obsess over this though. Guys gotta pick his battles, right? 👍 |
Those are very nice. Years ago, I had new tires put on my 85 Carrera's polished Fuchs. They came back from the tire shop with very nice chrome valves. I still think they look great. I may get a set of those from Tire Supply for my 73 911.
(man/dude)
Oh yes of course because kids might eat them..... and yes, the weights can be hidden!!
They are nice. But for those of you who are going to use rubber ones, get short stubby ones from the motorbike shop. They won't flex. The long floppy ones are for wheels with plastic wheel covers and need to be long. |
Ordered some! Thanks for sharing!
The metal ones tend to scuff the anodising.
These things look pretty cool, but with my luck, I will stick with the old school rubber. I think it is there for a reason. I suspect that a rigid metal stem mounted on a spinning car wheel at highway speed probably doesn't have to strike much mass in terms of road debris to crack or just snap off. A rubber stem can deflect and has a better chance of survival, doesn't require special thought to seal, etc. To each his own.
On the question of weights, what's the consensus on use of Dynabeads for dynamic balancing? I've used them on my motorcycles and they appear to work fine, but not used them on car tires. Opinions on this as an alternative to weights?
EDIT- Never mind, did a search and found some threads on this. |
Do you think they'll fit in these 9" Fuchs Evos?... ![]()
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Rey....77 930 "the Mistress" |
Perfect match on the new Fuchs Evolution rims👍
