It's a 914 ...
You'd think the Porsche OEM seals would be available from some other source. I mean, Porsche isn't manufacturing the seals ...
Vaguely interesting topic! I haven't had a problem with the single-lip Elring seals, either in their kits or as individual parts. The double-lipped version is a nice bit of insurance, no argument, against debris getting in. However, looking at the design of the outer lip, it is for debris and not oil sealing. The inner lip with its tighter design and gaiter provides the oil sealing.
I make a practice of checking the condition of the shaft where the seal lip rides. Often I will find they have a groove worn at that point, and that can cause seeping. This is especially common with the input shaft. There are a couple of fixes for this. One is to locate the seal at a slightly different depth, so its lip rides on an undamaged bit of the shaft. Another is to install an SKF Speedi Sleeve on the shaft, pretty cool fix. When assembling, be sure to pre-lubricate the shaft where the seal rides. I use a transmission assembly lube, but a smear of gear oil will do the job. Cheers,
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ Last edited by kevingross; 02-20-2022 at 09:30 AM.. |
Great timing as I'm about to replace these seals. I guess I'll pony up for oem
1985 Iris Blue M491 911 Coupe |
