Help!! 915 output shaft seal leak
I just resealed the gearbox on a 1981 SC. I've done this several times over the years on various other 911's without ever having any issues. But... on this one, I replaced the two output shaft flange seals with elring part number 999-113-183-40-M30 45x68x10. I was stunned to discover a profuse leak on the PS and a minor leak on the DS after a 5 mile test drive. I removed the PS seal and replaced with another brand new elring seal.
After a 3 mile run, it's leaking again. The PS is set exactly straight and 2mm recessed below the case cast and the DS is at 3mm. I tested the seal point where it rides on the flange after replacing the seal for the second time and is sits exactly on the shoulder where the original seal left its mark. Like I said, I've never had an issue with these leaking in the past. Is there more than one size option? Ever heard of elring having an issue with this? I've always used these seals and never had issues. Thanks for your input! ![]() ![]() ![]() |
UPDATE... I drained about 8 ounces of oil out since both sides are leaking and it made no difference. This isn't rocket science! I just can't believe this happening!!
It's a 914 ...
Seals normally have size markings on them to indicate OD, ID, and thickness. Any chance you have the wrong size? Leaking at the ID I assume?
No, the markings are correct, and yes leaking at the ID. I'm wondering if they are just a bad batch. I have nothing left to try other than get some expensive OEM seals I guess.
49willard
Not good news. I just replaced the seals on my Carrera with Elring seals, same part # as part of my functional refresh. There were no leaks before replacement. Engine and trans still out. Should go back together in a couple of weeks. Living in Maine it will be several months before I will take it out on the road. Who is the oem supplier? Is it Elring per chance? Unfortunately, thanks for the heads up.
Please keep us posted.
Bill 1961 356B coupe-long gone! 1986 Grand Prix White Cabriolet |
I have a few seals here that are probably from a job 2 years ago if you want I can send. Like you said maybe a bad batch
Instagram: @TuitTech |
I quit using the seals in the gasket sets, and use only Porsche purchased seals. I’d use Kaco seals if I could get them.
what is the oil you are using also ..it has been seen lately the quality of seals no matter which kind are getting worse..do try to reduce the length of the garter spring inside the seal..like this
start with cuttin about 3-4 mm https://www.youtube.com/watch?v=Q83YRYcSpDE https://www.youtube.com/watch?v=OYxcT40i700
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Mach925, I should of said Elring gaskets sets have Elring seals, doesn’t matter how u get them, in a set or separately.
Slip it on the seal ring of the drive flange to be sure it's a decent fit before installing it in the case.
I did... and it felt reasonable. I ordered the OEM seal and will have it tomorrow. I'll check the the fitment against the elring and report back. Thanks John.
Functionista
OE seals I have here say Kaco.
Agree with John, they have to fit well, no gaps. Be careful if you shorten the spring. Excessive seal friction won’t do your flanges any favors.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
OK - Problem solved. I received the OEM Porsche seals today. I took some photos of the obvious differences. The OEM seal has a double sealing lip and the elring has one. The OEM fitment on the shaft was slightly tighter than the elring. To be absolutely certain, I shortened the springs by about 3mm. Does not leak a drop. I've used the elring seals here before without issue, so there seems to be some quality control issues with the current batch at Pelican. It's obvious that the OEM seal design is far superior, so my recommendation is spend the extra $15 and forget about the elring in this application.
Caleb |
good investigation..i`ll go look at my stash tomorrow ..what seals i have...the quality sucks lately elring use to be the seals to go to..no longer....
Ivan
Back in post #7, see what I mean.
