RETIRED
Joe Bob's Avatar
You can revalve them but AFIK, Koni is THE adjustable shock to use....
2012 ML350 3.0 Turbo Diesel
Old 05-22-2003, 02:25 PM
Harry, I live across the street from Clear Lake in Friendswood.
I think the Bilstein DS9 stuff is adjustable, but I don't think they make it for anything earlier than the 993, or maybe the 964.
Old 05-22-2003, 02:29 PM
ted ted is online now
likes to left foot brake.
ted's Avatar
Originally posted by tommyd
Does any one have experience with Bilstein RSR struts that are suppose to help reduce bump steer issues with lowered cars?
In addition to ride height, RSR struts also modify the camber. Where with stock struts you might get almost -2 degrees camber, the RSR struts can have the axle welded to what ever camber spec you require.
Old 05-22-2003, 03:42 PM
Glasgow 911SC's Avatar
Tom
The rear shocks on my car aren't top adjustables. This means to change the setting you have to unbolt a load of stuff. I've set them to the second softest setting (out of 4) on recommendation. The fronts are top adjustable so (when fitted) you just turn the top of the shoch with the device provided & you're good to go.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 05-23-2003, 01:03 PM
Harry, congratulations on the new job. Like they told us in college, you can't keep a good chemical engineer down.
Ken
1980 930
Old 05-23-2003, 10:52 PM
HarryD's Avatar
Thanks.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-24-2003, 12:27 AM
zotman72's Avatar
I put a set of Bilstein RSR struts on my lowered '72 911S clone. They are not adjustable with t-bars but the option of changing the coilover springs (if you go that route rather than tbars) is there. The strut insert was set to a sport HD setting but I do not know what. The raised spindle height does counteract the bump steer issue without using the big washers under your steering box. HTH
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 05-24-2003, 08:53 AM
