RETIRED
You can revalve them but AFIK, Koni is THE adjustable shock to use....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Harry, I live across the street from Clear Lake in Friendswood.
I think the Bilstein DS9 stuff is adjustable, but I don't think they make it for anything earlier than the 993, or maybe the 964.
likes to left foot brake.
Tom
The rear shocks on my car aren't top adjustables. This means to change the setting you have to unbolt a load of stuff. I've set them to the second softest setting (out of 4) on recommendation. The fronts are top adjustable so (when fitted) you just turn the top of the shoch with the device provided & you're good to go.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Harry, congratulations on the new job. Like they told us in college, you can't keep a good chemical engineer down.
Ken 1980 930 |
I put a set of Bilstein RSR struts on my lowered '72 911S clone. They are not adjustable with t-bars but the option of changing the coilover springs (if you go that route rather than tbars) is there. The strut insert was set to a sport HD setting but I do not know what. The raised spindle height does counteract the bump steer issue without using the big washers under your steering box. HTH
Bill '72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride. |
