Originally Posted by Showdown View Post
Best to epoxy nuts into the 3D print for anything more than a small screw like those plastic screws in toys.
....yes, I agree and would not trust any screw thread in the plastic....it is the way to go and not terribly hard to model in F360....
So far, only fasteners I have with my projects are through holes where a bolt goes through the plastic into a metal captive nut or threads.
Needless to say, good, wide flat washers are a must.
Thanks!
D.
Old 02-03-2024, 11:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
Nice thread! at a first glance I thought that was a heater control box delete plug! Someone should make one, should be pretty easy to make and print.
Old 02-04-2024, 10:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
PSA - Bambu Lab has an active recall on the A1:
https://blog.bambulab.com/a1-recall-update/
Old 02-04-2024, 01:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
Interesting....thankfully I have an X1, so far no recalls (or problems in my case)....
D.
Old 02-04-2024, 01:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
Ok, a question and an update.
Question is, I am doing a bigger project with a complete centre console insert and want to do some quick and dirty PLA prints to just figure out if everything fits.
Did a bunch of searches on the web, could not seem to nail down how exactly I can reduce filament/time while keeping things dimensionally good and suitable for a functional check.
Any insight from anyone?
In terms of the new project, here it is:
I have a centre console from Better Bodies and have modified it to make it more durable.
The console will hold the door lock/alarm switch, a 7 light custom display showing status of park brake, WW fluid, brake system, oil cooler fan + hazard switch and rear defroster switch
It will also hold the 3 ventilation controls which will control auto heat, AC temp, AC fan, plus a slot for my Porsche Classic radio which has a little box for USB and CarPlay and of course the required mouse fur lined cubby.
Its the maximum size for my printer 256 mm, so its a lot of filament, final version will be done in either ABS, ASA or CF...
D.
Old 02-11-2024, 11:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
Full Send Society
DIY 3D Printing Tools and Parts Thread
Change the settings to extra draft, make the layers thicker and then adjust the amount of infill between the walls.
Also, consider printing it in pieces and then gluing it together. That may actually be stronger than a single print.
No magic bullet, big prints take a long time.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 02-11-2024, 11:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #146 (permalink)
I'd also suggest you try a larger nozzle size. going from 0.4 to 0.6 and thicker layers can make a big impact on print time
Its pretty simple to change the layer heights and nozzle size in the slicer to see impact on print times.
Also you can print fewer perimeters. The dimensions of the outside edges will be the same, but the parts will not be as strong.
But it doesn't really look like it will take long to print that part. Long in 3D printing terms is more than 24 hrs.
Old 02-11-2024, 12:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #147 (permalink)
"Long in 3D printing terms is more than 24 hrs. "
D.
Old 02-11-2024, 12:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #148 (permalink)
Reduce filament: On my printer / software combo (Ultimaker 2 / Cura) I have the ability to define the infill percentage. Reducing the amount of infill will reduce the filament and time to print. I often drop it to 18% when prototyping. I may go 100% on final print for strength.
Functional check: Depending on the orientation of what you're checking fitment of, you can abort the print once the base layer has sufficiently built up (~1mm). Then go put that in place and see if it's doing what you need. You've wasted that 1mm, but better than the time and filament of the whole model only to find out it wasn't going to fit anyway.
Old 02-12-2024, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #149 (permalink)
I also modify the file to eliminate all the stuff that is not necessary for thee test fit. Not sure if this applies to your case but test fitting this:
I drew this:
Old 02-12-2024, 11:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #150 (permalink)
Originally Posted by Peteinjp View Post
RMS seal tool
Can you post the file for that?
Old 02-13-2024, 01:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #151 (permalink)
Here ya go:
https://www.thingiverse.com/thing:6483628
Old 02-13-2024, 08:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #152 (permalink)
Ginger77's Avatar
Has anyone designed a VR crank sensor mount already?
I mean like the one that GoingSuperFast sold when they were still in business?
I really like 3d printing but I can't design myself. So this got me wondering if it's out there already?
Diederick
I drive a US import 1977 911. Formerly owned by a woman in California named Ginger - which appropriately led to the nickname.
IG: no dedicated account but photos are posted with #ginger77
Old 02-23-2024, 03:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #153 (permalink)
Full Send Society
I started to but lost steam as other things popped up on my plate.
I have a partial scan of that part of the engine that I can send you if you want to model something up.
Also, going super fast is still in business- I was emailing him not too long ago. He’s in Taiwain and a bit slow but still around.
-Julian
Old 02-23-2024, 05:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #154 (permalink)
scumbag
I have one of these on my car. Next time I'm in Chicago, I'll swing by Julian's and let him scan it so a full 3D model can be made.
JB, we have to remember to do this.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 02-23-2024, 07:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #155 (permalink)
Full Send Society
Hehe, look what I just found from GoingSuperFast…
I’ll model it up once I get my scanner back (I loaned it out).
-Julian
Old 02-23-2024, 07:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #156 (permalink)
Ginger77's Avatar
Awesome!
Diederick
Old 02-23-2024, 08:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #157 (permalink)
Well, after untold hours learning Fusion and getting it to do what I want, here is the final version of the centre console system I have been building for way too long.
Guts of it are the auto heat system, 3D printing matching holders for the AC temp and AC fan controls along with the inlet air for the little fan that senses interior temperature.
I had to disassemble the whole auto heat system and relocate the servo to behind this console, it connects to the original wires to the heater boxes via a custom Bowden cable
Build also includes a place for the PCCM box that allows you to connect your phone, a cubby hole to hold the phone and whatever else the wife wants to put there, a 7 light display with all the warning lights for the brake system (fluid low, circuit pressure mismatch and park brake), plus windshield washer fluid low, oil cooler fan indicator and check engine light from the Motec.
...that and the hazard, rear window defogger, electric antenna lift switch and the alarm system switch...well, it took a lot longer than I thought.
I printed in ABS and was distressed that the print quality varied with some warpage taking place on my previous "final" print. I added some mouse ears to hold it down a bit better, plus did a little redesign to eliminate the long runs on the thin bottom strip that was separating from the bed and warping.
Total parts count was 4 including the cubby and bottom plate currently in PLA with the ABS versions about to be printed.
Still lots to do, designing and printing the gubbins that align the rotary AC switches to the correct orientation and provide the "click", printing new labels that read right on the backlit switches and of course the knee pad centre piece that I am trying to design and print right now.
Then its cover the green part in the proper vinyl and putting it all together.
Love the Bambu, it's been very good and the AMS is definitely a must have, makes life so easy.
Bambu studio is a bit of a bear, but it's OK....Fusion is certainly not for the faint of heart, but I am getting there.
Take care all!
D.
Old 03-02-2024, 12:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #158 (permalink)
Carmagic.us
rothaus's Avatar
Wow, that's quite a project. Looks great.
Cheers
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 03-03-2024, 05:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #159 (permalink)
For those with Bambu spools and AMS:
I printed 2 of these (the outer 2, since I already have the hygrometer setup in the middle):
https://www.printables.com/model/423765-silica-dry-box-for-bambulab-ams-hydra
and a bunch of these that fit inside the bambu spools:
https://www.printables.com/model/536741-bambu-lab-re-usable-spool-desiccant-container
Both are high quality fits and designs.
-- they hold loose, reusable desiccant.
Brought my humidity to 10% and you can bake or microwave the loose desiccant to reuse it. It also changes color to orange when it become saturated so you know when to change -- same as I use in my air system.
https://www.amazon.com/dp/B013L31PQ0?ref=ppx_yo2ov_dt_b_product_details&th=1
Old 03-03-2024, 06:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #160 (permalink)
