1980 911 SC Door Latch Spring Replacement
Can anyone tell me a source for a spring that tethers the latch release bell-crank to the interior door panel (the spring pulls the interior door release lever back into position)? The spring is not called out in the Porsche factory catalog but it looks like a shorter version of the latch return spring on our host's site.
https://www.pelicanparts.com/More_Info/99353116501.htm?pn=993-531-165-01-OEM&q=993531#backToTopAnc.
The attached picture shows the location but with a spring from a kit that does not provide nearly enough tension.
Old 10-17-2022, 09:04 AM
Send a message via ICQ to AirJose
ago,
Take the spring out with the swivel base. Should be attached with Phillip small screws. Cut about 1/3 of that spring with a wire cutter, bend end to fit and re-attach it. Lubricate that swivel before installation. You should now have more tension. I have seen doors with it and without that spring (newer doors). I won't pay $20.00 for a 50-cent spring
Be careful not to pinch yourself with the spring wire (don't ask)
Best of luck,
Jose
Old 10-17-2022, 11:28 AM
Jose,
I gave up my search and did what you suggested with the broken factory spring; it worked well to bend the first turn of the coil into a loop to hook onto the door. Thank you!
Old 10-18-2022, 05:49 PM
Tags
door handle interior , door latch , latch
