front hood seal
Do you need to take the bumper and front smile off to replace the front hood seal?
no you do not..the only thing i remove is the vent grille..after make it a snug fit and after use 3m weater-strip adhesive--i use the yellow type..
Ivan
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks, the two little tabs that stick out from one end of the seal go under the smile. I did not know if I had to loosen the smile to get them out.
FWIW, the 3M yellow stuff is awesome. If you have never used it I urge you to follow the directions. If you do it sticks like super glue to your fingers! Very important to let it get tacky before sticking parts together.
no need to remove the smile ,just push it under
Ivan
Wildman Emeritus
+1 on the 3M. Stuff is magic and worth every penny.
Whatever you do, don't use silicone seal. Many have an etching agent which can mess with your paint and lead to rust.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Thread Tools | |
Rate This Thread | |
