DC Metro Targa glass install?
Does anyone have experience with a shop in the Washington, D.C. area to do a replacement of a Targa rear glass seal? I’d probably drive 1-2 hours if the job could be done while I wait. Thanks, Pelicans! Happy Holidays!
Old 12-18-2022, 04:35 PM
47silver's Avatar
Probably need to do it yourself. There are a couple threads on how to fo it.
Old 12-19-2022, 07:23 PM
1-2 hours more like 1-2 days.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-20-2022, 02:49 PM
47silver's Avatar
I chsnged mine 5 times by myself
Get a couple glass holders from harbor freight
A couple ratcheting straps
Put rubber on window
Slip 1/4” rope in seam
Place window on car
Draw window in with rachtes
I attached under the dash
As you slowly rachet pull out the string
Sprsy with water and dishwaher soap mix
Old 12-28-2022, 04:34 PM
Use Lemon Pledge
I know this sound crazy but it worked for me when I installed my windshield.
I got this trick from my Vanagon mechanic who has been installing VW windows for 30 years. Spray Lemon Pledge in the channels of the rubber where the lip of the frame will sit. It lubricates the rubber, is easy to clean, and apparently will not hurt the paint. I am sure dish detergent will work as well, but this was my first time and it went smoothly.
Good Luck
Kevin
Old 12-29-2022, 02:49 PM
I think the OP is asking about rear Targa glass not windshield, bigger project
Old 12-29-2022, 02:59 PM
I have to say, I'm in Northern Virginia, and I don't think there's a chance in the world that you want anything to do with a shop that will do this in a few hours. That's a shop that doesn't have enough work to stay busy, and there's a reason for that. It's winter, let it take a little time.
Old 12-29-2022, 03:01 PM
TWork's Avatar
I had the rear seal replaced in my '73 Targa a couple months ago. Very experienced place that does hot rods, etc. After 2 1/2 weeks, they were able to get it done, but swore they wouldn't do another. Started with an aftermarket seal, but ended up using the OEM Porsche gasket (didn't know it was available).
'73 Targa
Old 12-30-2022, 08:37 AM
First off the seal has to be at a good working temp. Then attached to the rear glass with trim installed. Taped everywhere to hold it in, then slowly lower into position. Pushing in while pulling rope to get the lip over the edge. The shop that works on my car has been in business for over 50 years and HATES this job!.
Trying to do this in the winter makes it even harder.
1991 C2 Turbo
Old 12-30-2022, 01:21 PM
'73 911 T Targa
I’d try Ralph Simmers. His shop is a little bit of a hike from DC, but If he can’t do it, he might know someone who can.
https://www.ralphsautoservice.net/
Old 12-30-2022, 03:34 PM
