Analog Air Cooled
That sucks. I’d restore it. Ya there a light to the DEF square on the floor. And yes, all three on the HVAC like you said.
Get a set of factory manuals. Lots online. 3.2 are easier than the sc diagrams but it’s all the same. The black plastic light holders may me broken but the should fit in the recepticle the panel. Seat back, feet back, and head under dash works. Taking the seat out is easier. Also, look at your ignition ring and see what’s been added. If you see a 4 pin connector up in there going no where and have manual pull heat, that’s the auto heat option.
86 Targa 91 964 13 6 SPD Cayenne |
It’s amazing the sin that occurs over time in these cars. I had 2 different car alarms hacked in, an aftermarket stereo with amplifier under the passenger floor board, and a 10 disc cd changer in the frunk. I removed all of it, including motion sensors behind the front bumper and other wiring that went into the engine bay.
All you’re showing can be repaired with wiring diagrams and a bit of effort. Keep at it, you’ll get there and have a bit of fun in the process. |
PCA Member since 1988
I installed a high-power digital media receiver in my 1973T a couple months ago (Sony DSX-M80). It required a high amp connection to the battery to power its internal amplifier. To get that, I ran a 12-gauge wire from the right-side battery (with inline fuse close to the battery) back along the inner fender to the back right corner of the frunk, to a wiring harness grommet in the firewall just ahead of the glove box. Then I fished the new wire through that grommet and to the back of the new radio. That's the easiest way to get a high-current always-on connection. The yellow with red stripe wire comes from the ignition switch, so use that for the ACC connection. Because I have a high-power radio, I also ran a separate 12-gauge brown wire from the radio to the strap that I screwed into the firewall. My radio has a light sensor so it auto dims when the light inside the cabin decreases.
Looks like your head unit is double in power so my set up will be basically the same (12gauge wire, ground, etc...): My stereo specs: ![]() My question would be (from earlier in the post) is I tested a wire, original from the car, and would that be safe to use for this head unit as the ACC wire? Once the car is on, if I am correct, the power for the head unit comes from there and was thinking on upgrading that wire/connection also. The factory harness wires just seem so old and small. Hope that is a valid concern...been a learning experience this week with the wiring here, pulling the alternator, new ignition switch and starter...so much relay research Thanks for the patience...stereo is secondary BUT want to do it right. Erik
1986 911 Coupe 1986 911 Targa |
No problem with using the yellow/red wire for powering the radio you have. You will notice that wire is heavier gauge than most, so it has plenty of "ampacity" for the radio.
Here's the reality: Although radios are rated at, say, 22W/ch RMS x 4 channels driven, the actual load is much lower. Because music is dynamic, the average power is maybe 10% of the "full" power. And even that is subjectively very loud. If it was delivering 22w x 4 (88W total) continuously, 88W divided by 14V =6.3 amps. That's well within the capacity of that yellow/red circuit. But, except for very short dynamic transients, the current will be below 1 amp. Bottom line: You will not stress that ACC circuit any more than the original radio. The reason I installed a 12 gauge wire directly to the battery are, (1) the instructions recommended it, and (2) I wanted to be sure that my high power unit has maximum current available so that it will not "clip" the high-power transient peaks in the music. FYI, the highest power requirements are for bass frequencies, and I like powerful bass.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 01-11-2023 at 09:24 PM.. |
Bitte ein Bit
Great timing, just sat down to order more parts and saw your response. I have read exactly what you have stated. You guys have been a big help and hopefully this thread helps others. Sadly, electronics and wiring past just basic weren't part of growing up for me...but the more I dig in honestly it's really not too hard - and again, help from everyone with experience or knowledge is making things understandable. Articles and videos can only take you so far. Thanks! Erik Last edited by Bitte ein Bit; 01-11-2023 at 12:41 PM.. |
Dropped a few pounds of excess wire (previous owner) and the original factory stereo radio/speaker wire - in the end could not find an accessible ACC wire.
So, I am reading and thinking I can run an ACC wire from the head unit directly to the fuse panel. Reading nightly and trying to understand from old threads and electronic articles I can't quite get the answer I am looking for. So, hopefully last question(s): Can I run a fused wire (10/15/20a) from the head unit directly to my fuse panel and connect at lets say (for my year 1986) the fuse at the "fresh air blower/cigarette lighter/rear window defroster"??? Head uit does have a 10a fuse built in... I never use these accesories, other than the cigarette lighter for a plug in volt meter on trips. My follow up would be does it matter when making a connection like this to use the top connector at the fuse panel or the bottom connection??? That's about it...again thanks to the community for insight and advice. Regards, Erik
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Radio
Pm & email sent.
Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 01-23-2023 at 07:29 PM.. Reason: Text |
One thing that confused me was that some of the fuses don't have any connection at the top, but it turns out some of them are connected on the backside of the panel.
1978 911SC with Lobster Interior - Zoidberg http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html |
Thanks! Erik
Erik
To be sure, take out the fuse and check both ends of the fuse holder for voltage. The one with voltage is the "hot" side, and the other side is protected by the fuse. Use the protected side.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Already did this and thanks, good advice. I was checking and thought to myself - 'just remove the fuse and check' so easy to forget the simple things.... Erik
