Weber carburetor help
All,
I have a 1970 factory 914-6 with the original Webers on it. It has been running great up until recently, when it started to misfire on one cylinder.
I started troubleshooting and found that #5 is dead. The first thing I did was pull the spark plug and replace it. No results.
I swapped the #5 and #6 plug wires, the miss stayed on #5.
I ran a compression test on the engine, all of them show approximately 155 psi.
I put the plug back in, and fired it back up. I then took a gas torch and slowly fed acetylene into the stack on #5. The idle sped up and smoothed out.
So I pulled all the jets in the carb and cleaned them. I pulled the top and checked the air bleeds, and the aux venturi for any blockages. Every passage tests to be clear. Even the accelerator pump works correctly.
Frankly, I am stumped on this one. Can anyone think of something I missed?
Thanks in Advance!
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 06-16-2023, 03:04 PM
Are you sure you have spark? Test #5 with a spare plug against ground while running?
Acetylene is pretty reactive might not be the best confirmation of spark/ lack of fuel.
Sent from my Pixel 7 using Tapatalk
Old 06-16-2023, 03:25 PM
I just went out in the garage and double checked it. I hooked the plug wire to a new spark plug and put it on top of the motor. I am getting a good spark.
Clay Perrine
95 BMW 540i (Inga)
Old 06-16-2023, 03:44 PM
7.0:1 > 11.3:1 > 7.0:1
Seems like your acetylene test verifies you have spark but lacking fuel.
Is the misfire only at idle (idle circuit) or under load?
I’m not a carb guru, just trying to help narrow it down.
Old 06-16-2023, 08:12 PM
Exactly. If #5 is not firing at idle only or not firing under load is a big question
Old 06-17-2023, 03:28 AM
Originally Posted by Clay Perrine View Post
All,
Thanks in Advance!
Do you try cleaning the hidden gallery between bottom of emulsion tube and idle jet?
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 06-17-2023, 04:38 AM
I got the email you sent to me with the info on the hidden gallery. I am very reluctant to go that deep into the carb. I am going to seek professional help.
Thanks everyone.
Clay Perrine
95 BMW 540i (Inga)
Old 06-19-2023, 05:34 AM
