Weber carburetor help
All,
I have a 1970 factory 914-6 with the original Webers on it. It has been running great up until recently, when it started to misfire on one cylinder. I started troubleshooting and found that #5 is dead. The first thing I did was pull the spark plug and replace it. No results. I swapped the #5 and #6 plug wires, the miss stayed on #5. I ran a compression test on the engine, all of them show approximately 155 psi. I put the plug back in, and fired it back up. I then took a gas torch and slowly fed acetylene into the stack on #5. The idle sped up and smoothed out. So I pulled all the jets in the carb and cleaned them. I pulled the top and checked the air bleeds, and the aux venturi for any blockages. Every passage tests to be clear. Even the accelerator pump works correctly. Frankly, I am stumped on this one. Can anyone think of something I missed? Thanks in Advance!
Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga) |
Are you sure you have spark? Test #5 with a spare plug against ground while running?
Acetylene is pretty reactive might not be the best confirmation of spark/ lack of fuel. Sent from my Pixel 7 using Tapatalk |
I just went out in the garage and double checked it. I hooked the plug wire to a new spark plug and put it on top of the motor. I am getting a good spark.
7.0:1 > 11.3:1 > 7.0:1
Seems like your acetylene test verifies you have spark but lacking fuel.
Is the misfire only at idle (idle circuit) or under load? I’m not a carb guru, just trying to help narrow it down. |
Exactly. If #5 is not firing at idle only or not firing under load is a big question
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
Thanks everyone.
