H.G.P.'s Avatar
What properties of an oil (excluding "higher mileage"oils), might cause leaks to slow
What properties of an oil (excluding "higher mileage" oils), might cause leaks to slow or stop?
I am not referring to a change from a pre-existing synthetic, but instead switching to something like Kendall 20-50 from a regular oil. Since the switch, I have had a leak stop/slow. What's the theory here?
1969 911 E Coupe
"Little Bull" "Horse"
1969 911 E Coupe
"H." Heart, "G." Gears, and "P" the Porsche
Old 06-10-2003, 04:35 PM
The short answer is "a different additive package".
Jerry M
'78 SC
Old 06-10-2003, 05:00 PM
H.G.P.'s Avatar
"Additives"? As in producing a differing flow rate? Qualitative flow rate at different temperatures?
1969 911 E Coupe
Old 06-10-2003, 05:16 PM
Platelets??
Just kidding
Old 06-10-2003, 05:40 PM
If you're asking "what is the additive in oil A that allows for less consumption than oil B?", I have no idea. I'm not a chemical engineer, and additive packages are a complex combination of substances\chemicals designed to do everything from increasing viscosity to reducing scuffing. Perhaps a petro-chemical engineer will jump in with definitive answer, but I don't think so, without a great deal more information.
Jerry M
'78 SC
Old 06-10-2003, 06:48 PM
