RETIRED
windshield wiper frozen
Not the fuse...what else to check?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
IT was the fuse 25 amp....but it keeps popping. Suggestions are welcomed
I would isolate the motor from the linkage. Can be done working through the clock hole I think. Remove the nut on the motor shaft and you will see if the motor runs or if the linkage is frozen.
RETIRED
When the fuse was replaced it turned a quarter rotation and then popped. Going to purchase some more fuses......I'll pull the nut, replace the fuse and see it works without tension.....
