RETIRED
Joe Bob's Avatar
windshield wiper frozen
Not the fuse...what else to check?
2012 ML350 3.0 Turbo Diesel
Old 04-07-2024, 01:26 PM
RETIRED
Joe Bob's Avatar
IT was the fuse 25 amp....but it keeps popping. Suggestions are welcomed
Old 04-13-2024, 10:38 AM
I would isolate the motor from the linkage. Can be done working through the clock hole I think. Remove the nut on the motor shaft and you will see if the motor runs or if the linkage is frozen.
Old 04-14-2024, 03:16 PM
RETIRED
Joe Bob's Avatar
When the fuse was replaced it turned a quarter rotation and then popped. Going to purchase some more fuses......I'll pull the nut, replace the fuse and see it works without tension.....
Old 04-16-2024, 12:48 AM
