The side jack point are made for the emergency jack when changing tires. The alternate teeter tottering is a perfect way to have the car slide of the jack and or jack stands, I've seen it on this board, I've seen it in real life... You can all imagine the fun of that.
If you don't want to use the most common and tired method used by Porsche mechanics since the inception of the 911, then use two jacks under the rear part of the rockers. When you have jack stands under the torsion bars, then you can jack the front on most anything in the front,doesn't even have to be in the middle, its very light. On my track car I've added a jack point to the rear engine mount, between the engine and the muffler, perfect jack point.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
PCA Member since 1988
I Use that front center channel all the time to jack up my 1973. I put a 2x6 piece of wood between the jack saddle and the channel. I haven't even messed up the undercoat doing it that way for years. It's a sold part of the body. If it isn't solid, then it's rusting out internally and should be replaced.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
