Adjusting valves Just before TDC?
I noticed while adjusting my valves, that the most amount of slack I found was just before TDC and on the other cylinders just before the 120 degree mark rightfully.
If I continued onto TDC it tightens up a bit. I have a feeler gauge that I used and set them to on their rightful strokes. However if just before the stroke there is all this slack Im feeling, wouldn't that be a case for concern? |
Following
Sent from my iPhone using Tapatalk |
Wellinginc1,
You should watch a YouTube video on how to do this: https://www.youtube.com/watch?v=DQI9OR0Vt4w If the engine is in the correct position for valve adjustment, rotating the engine several degrees should not make any difference. The cam lobe should be on the "base circle" during valve adjustment. https://www.google.com/url?sa=i&url=https%3A%2F%2Fegnation.com%2F2016%2F11%2F21%2F all-about-that-base-circle%2F&psig=AOvVaw1aE1t91tq8LYFt-iISzzu3&ust=1693523278535000&source=images&cd=vfe&opi=89978449&ved=0CA8QjRxqFwoTCJjkx_-_hYEDFQAAAAAdAAAAABAE
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 08-30-2023 at 04:10 PM.. |
Correct Stroke………
Are you sure you are doing the valve lash adjustment at the right stroke (Z1 compression)? Tony |
sounds like you r in valve overlap for the cyl u r adjusting.
not compression stroke
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
