dannichols1474's Avatar
Here is some more data from an injector supplier who has worked with Bosch Motorsports.
The data is for 2 different product series, and are tables of injector dead times for pressure versus battery voltage. I am putting this out here for information only - the data shouldn't be used as is, it is just to illustrate some of the discussion points that have been made in this thread regarding fuel injectors and their dead time (or latency or offset).
Discussion points:
1. Higher battery voltage results in shorter dead times.
2. Higher fuel pressure results in longer dead times.
What jumps out at me from this data is that fuel pressure changes (40 to 100 psi) at lower battery voltages (8 V) result in much larger changes in dead time (delta of approx 1.0 ms) than the same fuel pressure changes (40 to 100 psi) at higher battery voltages (16 V) (delta of approx 0.1 ms).
Interesting.
Dan
1975 911 Carrera
"CIS to ITB EFI conversion" thread
Updated (2) Table of Contents pg17 post 339
Old 06-27-2025, 07:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #421 (permalink)
Racer
winders's Avatar
The bottomline is that at normal street battery voltages the difference in dead time when going from 43.5 psi to 60 psi is quite small and nothing to get excited about.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 06-28-2025, 11:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #422 (permalink)
Senior Member
this is a little off topic here as I am doing carbs but should have some cross over info
1978 ROW 911 SC with large port heads (39mm) - planning to use PMO intake headers (PM-O911-0) which are the 46/39mm Tall for CIS.
looking at gaskets and heat insulators - for CIS heads there appears to be only 38mm or 40mm - which is the preferred size for my application - go undersize or go oversize
my apologies for being a bit off topic but this thread is a lot more active than the one I started.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 07-01-2025, 05:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #423 (permalink)
I would go with the 40mm gaskets and keep them out of the air flow.
Dan
1975 911 Carrera
Old 07-01-2025, 07:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #424 (permalink)
Senior Member
would there be any concern with the .5mm exposed portion of the head...
maybe a stupid question but there it is
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 07-01-2025, 07:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #425 (permalink)
Full Send Society
I'd either go 40mm and keep that .5mm out of the airflow as Dan suggested-it's just going to create turbulence where you don't want it, or have custom gaskets made. A laser cutter and a scanner and it's a piece of cake. I'm sure you could have it done online too.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 07-01-2025, 08:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #426 (permalink)
Dyno Tune After Fuel Pressure Increase
I went to the dyno tuning shop and got my car tuned after I increased the fuel pressure from 37 psi to 50 psi. Max injector flow has gone from 29.0 lbs/hr to 33.7 lbs/hr.
The injector % duty cycle at 7200 rpm was 89% with 37 psi, now the % duty cycle at 7200 rpm is 72% with 50 psi.
Difference report for the VE table, left side graph is 50 psi & right side graph is 37 psi.
The engine made a little bit more hp at the top with 1 degree more advance at 6500 - 7500 rpm as shown in the difference report for the Ignition table, left side graph is 50 psi & right side graph is 37 psi.
The dyno graph shows max wheel torque unchanged at 206.5 ft-lbs while max wheel hp increased from 232.8 hp @ 6600 rpm to 238.1 hp @ 7100 rpm.
Thank you Dave (montauk) for asking me why I was running with the fuel pressure so low. From the resulting discussion on this thread and observations made while working on my tune, I have learned a bunch and gotten a better performing engine as a result.
Dan
1975 911 Carrera
Old 07-01-2025, 09:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #427 (permalink)
Dan,
That's great news. Thanks for posting!!
Dave
1980 911SC Targa
1990 S2 Cabrio (sold)
2004 C4S (sold)
2006 Boxster (sold)
Old 07-02-2025, 04:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #428 (permalink)
Dan
Did you end up installing a fuel pulse damper on your setup?
I’ve been chasing some odd behavior in my long-term fuel trim table—huge swings between adjacent cells, like the ones in the screenshot I attached. From what I understand, that kind of variation really shouldn’t be happening under steady-state conditions.
After reading through some of what Rivet and Winders shared, I started wondering whether those big jumps could be due to slight fluctuations in fuel pressure. During driving, my gauge reads a pretty consistent 45 PSI, but when I reviewed the fuel pressure graph, there are some subtle oscillations riding on top of that flat line.
I decided to order a Holley 12-1004 AN6 fuel damper and plan to install it this weekend. One gripe though—the fitting uses a male AN6 ORB connection, so it relies on an O-ring rather than the usual 37° flare. Not ideal, but I’m hoping it takes the edge off those pressure ripples and smooths out the trims.
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 07-03-2025, 04:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #429 (permalink)
Originally Posted by montauk View Post
Dan
No, I am running the CIS Fuel Accumulator between the fuel pump and the FPR, then the fuel supply deadheads to the fuel rails.
Regarding your long term fuel trim screenshot, do those dips move around from one run to another (that is moving to different rpm / TPS conditions)?
My experience with OEM emissions systems is that long term trim changes more slowly. If the LTFT dip persists, then it would indicate the base fuel trim map is too rich in those areas - 1500 to 2500 rpm at low TPS is like pulling away from a stop with light throttle then cruising around the neighborhood?
Anyway, back to my fuel set up and observed fuel pressure changes. While Gary Bains was running the car on the dyno, I stood at the back of the car and watched the fuel pressure readings (my MegaSquirt 2 doesn't have an input for fuel pressure).
When Gary floored the gas (WOT) at 2000 rpm, the fuel pressure would drop from 50 to 48 psi then recover to 50 psi after 1 second or so and then stay steady at 50 psi through the rest of the WOT ramp run until after 7000 rpm and the fuel pressure would start to drop slightly (not sure of the amount, only that I started to see the gauge slowly moving lower), but then at 7300 rpm Gary ended the ramp run and the fuel pressure went back to 50 psi. That indicates to me that my fuel pump may be getting flow limited above 7000 rpm. If I was a racer, I would be thinking about a higher flow rate fuel pump, but for canyon carving and cars & coffee duty I am okay with what I have.
Dan
1975 911 Carrera
Old 07-03-2025, 10:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #430 (permalink)
The graph represents the long term trim after running the car quite a bit and applying those long term corrections to the base map. At this point, I shouldn't be seeing dips like that. You can see that the adjustments around the big dip area are modest. More to play with but I'm enjoying the process.
BTW, I finally drove the car, about 100 miles, on Monday without logging data. The laptop was with me just in case but it wasn't needed.
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 07-03-2025, 11:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #431 (permalink)
Results May Vary Esspecially When You're Working On Somebody Else's Car
Here is a tale of caution for those of you considering a CIS to ITB EFI conversion.
Earlier this year I met Andy at a local PCA cars & coffee in Soquel. Andy has a 74 911 and he added a wide body kit, rebuilt and swapped in a 3.0L SC motor which he had converted the CIS to ITB EFI. So, given that I also have similar motor work on my 75 Carrera, we hit it off and became friends.
Andy has a friend, Todd, that owns a 79 911 SC 3.0L and Todd saw my ITB EFI set up and decided he wanted that too. Well, Todd paints cars and Andy has a 64 356C that he wanted to get painted (Todd had painted Andy's 74 911 previously and was happy with the result), so Todd and Andy worked out a deal: Todd paints Andy's 356 and Andy converts Todd's SC to ITB EFI.
Andy knows Al Kosmal at X-Faktory.com and decides to buy Al's Option 3 conversion kit (MegaSquirt3 + MS3X expansion board, etc...) because Andy and Todd decide they want to run a coil on plug (COP) set up instead of using the distributor. Andy also decides not to install the Clewett Engineering cam position sensor so this will be a semi-sequential FI with COP waste ignition system.
Since Andy's 74 911 is running an old AEM Infinity ECU, he is not familiar with MegaSquirt and asks me to help with the MegaSquirt tune file set up and VE table tuning duties. Little did I know what I was signing myself up for.
On the first page of Al's installation document is a clear statement about how the target vehicle must be in good running condition or else the ITB EFI installation will become an "advanced" installation requiring more work.
Well, I had never seen Todd's car until I made my first trip down to Andy's house in Salinas. This 79 911 SC looks nice on the outside with a fresh coat of GP White paint and Turbo whale tail spoiler, but beneath that exterior is a car that had obviously been run hard and not well cared for. The exhaust was pretty rusted, the CV prop shafts had inner rubber boots that weren't secured so all the inner CV joint grease was gone, the brakes are completely used up and the shifter bushings and coupler are completely worn out such that the gear shift lever just flops around. Andy corrected the exhaust and CV shaft issues by installing SSI's + a new muffler and new CV prop shafts.
Andy's installation of the ITB's and the EFI + COP hardware and wiring is first rate. He mounted the ECU + a relay board to an aluminum plate and mounted that to the floor pan under the passenger seat. All of the wiring connections are located in the rear shock upper mount cross member area and he used the ground lug on the left rear inner fender (behind where the old fuel accumulator and fuel filter were located) for the EFI ground terminations. Switched 12V is coming from the ignition switch and main relay power (connected to terminal #30 on the relays) is via a 4 gauge cable connected to the battery + terminal at the starter.
The existing wiring is messy as a car alarm system and who knows what else had been added then removed in the past. There are stray wires in multiple places under the front hood near the main fuse panel and under the dash. There is also a ground shut off switch on the battery ground cable with about 30% of the cable strands cut away to allow installation of the shut off switch.
There is also a problem with the alternator which is a replacement unit with an integrated voltage regulator as the original voltage regulator had been removed. The problem is that the generator charge warning light in the dash gauge stays lit even when the starter key switch is in the off position. This turns out to be the reason the battery ground shut off switch was installed.
You probably know where this story is headed....
So before hand, I had set up a tune file using the MS3 sample project in TunerStudio and used the my VE table, AFR table and ignition table values to create those tables for Todd's set up - I rescaled the rpm to 6500 rpm max and I converted the ignition table from 12 x 12 (MS2 standard) to 16 x 16 (MS3 standard). Load sense is Alpha-n using the TPS. The FI is using the MS3X board outputs and is set for semi-sequential. The ignition is using a 36-1 trigger wheel/crankshaft pulley with a Hall effect sensor and a plug to fill the distributor shaft opening in the crankcase (from Clewett Engineering) and Denso style COP units. The ignition outputs are set to COP waste.
I loaded my tune program into the ECU and entered calibration data for the CLT (coolant temp), IAT (manifold air temp) and wideband O2 sensors. We counted the trigger wheel spaces from the case parting line to the crank position sensor, multiplied by 10 and entered the result in the "Tooth #1 Angle(deg BTDC)" field.
Then we opened up the ITB's a bit. Powered up the fuel pump and performed a leak check and regulator pressure adjustment (I set the fuel pressure to 50 psi) without problems.
Then we tried starting the engine - nothing. We spent the next 3 hours checking and retrying. Got a few back fires; otherwise, nothing. By now the battery was low, so we stopped, hooked up the battery charger and called it a day.
I decided to reload / update the ECU firmware so I downloaded the current firmware revision from DIYAutoTune.com to my laptop. I also spent an hour practicing how to perform the Inj/Spark tests in TunerStudio using my car as a test mule.
Several days later, I made the trip back down to Andy's house. I was able to successfully update the MS3 firmware from rev 1.5.2 to rev 1.6.1 and verified the tune file was correct. I was able to successfully test all 6 injectors and all 6 COP units so I knew the injector and COP units were wired in the firing order correctly.
Then we tried starting the engine. This time it started but ran horribly and the TunerStudio dashboard was showing the rpm read out jumping all around and the sync error status light was blinking - it was a mess.
We took a break and headed out to get some lunch. As we went over what we were seeing, we kept coming back to that generator charging light problem. Was the alternator output noisy? I didn't have my oscilloscope with me, but could we isolate the EFI electrical system from the charging system? Then Andy said, why don't we remove the fan belt so the alternator doesn't turn and try starting the engine?
So we went back to Andy's and did that, and the engine started and ran more or less normally, given we still need to verify the timing, sync the ITB's and tune the VE table.
Now a new alternator, new battery ground cable, and a new engine/transaxle ground strap are on order and once received and installed, we can try again to get this CIS to ITB EFI conversion up and running so we can then get Todd's car on the road and use the auto tune function in TunerStudio to dial in the VE table.
Stay tuned....
Dan
1975 911 Carrera
Old 08-11-2025, 09:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #432 (permalink)
al lkosmal's Avatar
Alternator info
Dan,
I am glad that you and Andy are working together on this one.
Here is good info regarding the install of an alternator with integrated regulator
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 08-11-2025, 10:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #433 (permalink)
Full Send Society
Yikes!
I was at a show talking to a fella about efi and he seemed convinced that “the computer will fix it” if there were problems as if the computer was an all knowing entity capable of miracles.
I told him that efi will amplify any issues that CIS can hide.
-Julian
Old 08-12-2025, 04:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #434 (permalink)
Racer
winders's Avatar
Originally Posted by Showdown View Post
Yikes!
CIS can't "hide" anything. CIS is far less flexible than EFI as the ECU, the "computer", that controls the EFI system can make adjustments based on far more variables and, depending on the ECU, can even "autotune" to an extent.
So no, EFI will not "amplify" any issues.
Scott Winders
PCA GT3 #3
Old 08-12-2025, 01:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #435 (permalink)
Full Send Society
Perhaps "hide" was the wrong word.... Tolerate, compensate, accept...
CIS is a pretty forgiving system and can run with all sorts of problems. Case in point; the hundreds of CIS Porsches out there that run and drive with little quirks, nuisances or deficiencies, but run nonetheless. Air leaks, pressure issues, WUR problems... the cars my not run well but they run and CIS tolerates it. Take that same car and throw EFI on it and the small issues that CIS can tolerate become major issues for EFI. Sure, you can modify the tune to compensate but that's crappy practice and not the correct way of going about things.
EFI depends on the tune which in turn depends on the tuner. There are countless options and features and tweaks that can be done in an EFI system (regardless of the ECU) and knowing how to work all of those is a lot and it's very easy to start chasing one's tail.
Ask any EFI ECU manufacturer, any tuner, any shop and to a T some version of "you have to have a well sorted car before going to EFI" will be their gospel.
But what do I know, feel free to take a crap funning CIS car and throw an EFI system on it and have at it.
-Julian
Old 08-12-2025, 01:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #436 (permalink)
Racer
winders's Avatar
CIS is not better than EFI in any way, shape, or form. CIS is just an electromechanical injection system. It does not tolerate or compensate for issues better than EFI. It just doesn't know the issues are there to begin with. EFI systems are far more flexible and make it easier to diagnose problems when they occur.
Scott Winders
PCA GT3 #3
Old 08-14-2025, 07:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #437 (permalink)
One thing I’ve come to appreciate is how fault-tolerant modern EFI systems can be. Even with a rough initial tune, the car can run surprisingly well—mine certainly did. And as the tune improves, so does drivability and performance. Dan’s setup is a great example: his car was running well even with low fuel pressure. Modern cars even have a limp home mode to compensate for failing components.
But this isn’t unique to EFI. CIS is also a tuned system, and every component was carefully selected to make the engine run optimally. The Warm-Up Regulator (WUR) is a perfect example—swap in the wrong one, and the engine might still run, but not as it was designed to.
Whether you’re running EFI, CIS, or carbs, the underlying engine condition matters. A well-tuned system can compensate for a lot, but to get the most out of any setup, the engine itself needs to be in great shape. That’s the foundation everything else builds on.
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 08-14-2025, 08:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #438 (permalink)
Suspension Refresh
The P75 is running well, but handling was getting vague - it just didn't want to take a set in the corners anymore.
Anyway, I was at a PCA C&C / Tech Talk at Beeline Motor Club in Santa Cruz and the subject was F and G model suspension rebuilds. The presentation was informative and the shop looked relatively neat and organized so I decided to let Beeline rebuild my front and rear suspension.
In the front, they replaced the lower control arms, the ball joints, the wheel bearings, the strut damper inserts (I replaced the old Bilsteins with new, the green ones), and the steering tie rods (updated 930 type).
In the rear, they replaced the spring plates / bushings with new adjustable units, the swing arm bushings, the wheel bearings, the axle shafts, the shock absorbers, and the rear sway bar mounting consoles.
I reused the torsion bars (22mm hollow front & 27mm hollow rear) and sway bars which I had installed in 2007.
Then they corner balanced and aligned the suspension.
The result was immediately noticeable. The car feels much more planted to the road going around corners and high speed stability on the freeway is much improved.
Front suspension photos:
Rear suspension photos:
Dan
1975 911 Carrera
Old 10-20-2025, 08:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #439 (permalink)
safe's Avatar
Yikes!
He is right. A "computer" will remove any problem the CIS is having.
There is ZERO reasons to first fix the CIS before removing it. Just make sure, with a leak down test, that the engine is mechanically okey.
Magnus
Old 10-21-2025, 04:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #440 (permalink)
