1984 Targa engine pull, speedometer sensor wire?
I am starting the process to remove my engine and transmission.
Do I need to disconnect the speedometer wire from the side of the transmission, or does that run through the engine harness connector?
Old 12-29-2023, 10:08 PM
Disconnect it in the shift coupler area and push the connector through the firewall. You'll be disconnecting the coupler anyway.
206 637 4071
Old 12-29-2023, 10:37 PM
