dragging Caliper?
1986 3.2, 125K Miles
Spent $3k on brake work about 1000 miles ago but have a recent problem with them.
When the car gets warm ( 10-20 miles) I get a "droning" sound from the front.
When I stop, the LF wheel is fairly warm, the RF is not.
My guess is a caliper binding the rotor.
Any opinions before I go back to my Indy shop?
Old 01-06-2024, 01:20 PM
Did your shop rebuild the calipers?
Old 01-06-2024, 03:01 PM
I would check wheel bearings if it drones.
Sent from my Pixel 7 using Tapatalk
Old 01-06-2024, 04:39 PM
What brake work was done and when was it done. 1,000 miles could be last year or 10 years ago and that would make a big difference in my opinion of what could be wrong.
If the soft lines weren't replaced as part of the brake work they could have gotten spongy and be causing the pads to not return properly. Especially if they could be original to the car. That was happening on my '84
Old 01-06-2024, 06:52 PM
PCA Member since 1988
If one rotor is hot, and the other one isn't as hot, then you are dragging. If the rotors are about the same temp, but the hub is hotter than the other side, then wheel bearing.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-07-2024, 12:53 AM
replaced with rebult caliper, works fine now
Old 07-14-2025, 06:56 AM
fallingat120mph's Avatar
Nice to see an update...and good outcome.
Erik
1986 911 Coupe
1986 911 Targa
Old 07-14-2025, 01:37 PM
Paid $250 with the exchange.
Could have had a new caliper from Amazon for $50!
Old 07-14-2025, 02:37 PM
