"Automotive Handbook - Second Addition", Bosch, 1986, pg 439, ISBN 0-89883-518-C A key point of this thread should be that once the AFRs are near optimum, more significant torque improvements typically result from tweaking ignition maps, not withstanding detonation. This doesn't imply, though, that ignition tweaking may not be detrimental. Without knock control, a high load, high temp, and/or low octane fuel are problematic with an excessive timing advance. The issue of detonation is not easily simulated/determined based on "dyno results".
Dave Last edited by mysocal911; 03-03-2024 at 08:50 PM.. |
PCA Member since 1988
Chris, all good discussion. You have picked up a lot of good info from those sources. When you tune for best power and torque, You end up at Bosch's numbers, or very close to them. Bosch has done more research and development on fuel injection, ignition, emissions, engine management, and other vehicle systems than anybody else, and owns most of the patents which other makers and OE manufacturers license from them. Therefore, I tend to take what they publish as gospel.
Let's see what crashmy911's subsequent tuning yields.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-03-2024 at 11:46 PM.. |
Yeah Pete, the more I've learned about I.C.E. in general as well as EFI I'm learning g that everything is dependent on something else and more often than not there is no one right answer to something. "It depends" seems like the answer that best fits most questions. Fun learning new things though I still like tuning a Weber sidedraft carb more than EFI. That has been a real learning curve for me.
The grind on my cams #171e/149i
Thanks, for the cam info.
john |
Forget all the hypothetical discussion.
Tune the car on the dyno, adjust AFR and timing live on the dyno to make max HP/TQ. Back timing off 1-2 degrees at peak for safety..... You will find that the AFR will likely be in the range of the posted numbers of others.... If this car was actually live tuned on a dyno that produced that AFR, maybe look for a different tuner, unless, they spent lots of time moving the AFR around and those numbers produced the peak HP/TQ
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Dave |
