Over rev - 3.2 Engine Vibration @ 2,000-3,400rpm. Missed Shift...
Hi Guys
I'm looking for help re next steps to diagnose a vibration that my 3.2 (930/20) engine has developed after a recent track day. It drove to the track and ran flawlessly all day and then driving home I noticed a vibration under load around 3,000rpm. In the first lap of my last sprint, I grabbed second shifting to fourth from third. I felt the change wasn't right and didn't left the clutch all the way out. Looking at the in car footage the tach went to circa 7,200rpm. Still having good oil pressure etc and still sounding great I kept going for the remaining 4 laps. It idles and drives great with no knocking or odd noises aside this vibration.
When driving and stationery (more noticeable, with and without clutch engaged) I can notice a slight (moderate if very fussy - maybe I am!) but definite vibration from approximately 1,800rpm and it starts to taper off after 3,400rpm. It is worst from 2,600 to 3,200.
Things checked to date or observations from taking the motor out and splitting the gearbox:
- engine mounts good but changed to try difference(including cracking and re tightening the 4 cradle bolts). No improvement.
- compression test was good with all cylinders within 7% of each other.
- Leak down was good, all cylinders 2% - 5% loss.
- bores look great and no material marks on the piston tops.
- clutch and pressure plate look fine.
- gearbox bell housing was quite wet with oil (rear main seal now done)
- disconnected fan belt, vibration remains.
I am 7 days away from driving 2,200km for a 2 day circuit sprint event and hoping to get some more ideas to rule out any terminal issues ie stretched rod bolts etc.
Any help appreciated!
Kind regards Tom
Old 03-18-2024, 08:12 PM
Alan L's Avatar
I guess the Q is - how bad is it? Is it something that has always been there and you just noticed it after the bad shift. Would any one else spot it? Is it really obvious? All engines have a harmonic pattern.
If it really did not go over 7200 everything should still be intact.
I am impressed your synchros did not give up.
It possibly could be in the clutch since that probably took the brunt. Maybe something bent.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-18-2024, 08:36 PM
I know!! The synchros aren't normally that good on the street that's for sure, haha.
The thought that it's always been there has crossed my mind, but I don't think so. It is definitely noticeable if looking for it and a trained person would pick it but it is not 'bad' no.
Old 03-18-2024, 09:06 PM
Check for an ignition problem. Blown off plug lead
All your test results show the engine is in good condition
all 911's are good for 7200-7300 rpm , yes the 3.2 has the less desireable rodbolts , but you did not throw a rod .
It just sounds like a miss to me
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 03-18-2024, 11:56 PM
Ian
Okay thanks, good call. I am waiting on a new dizzy cap and rotor. I noticed when doing the leak down that rhe rotor has a burnt out hole in the black resin part... Perhaps!?
Old 03-19-2024, 04:36 AM
It's a 914 ...
stownsen914's Avatar
A Porsche machinist once told me that overrevving a 911 can cause the clutch pressure plate to go out of balance, in his experience.
Old 03-19-2024, 04:54 AM
scarceller's Avatar
My thoughts were the same, maybe clutch related?
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 03-19-2024, 06:35 AM
Alan L's Avatar
Yes - I wondered clutch. But he says makes no difference - clutch engaged or not. So that throws you off the scent a bit. But I would still be suspicious in that area unless another cause is found. Possibly a bent input shaft or similar, or something bent in the clutch. It would have been severely stressed.
Alan
Old 03-19-2024, 10:20 AM
PCA Member since 1988
I'll echo Ian's suggestion to check the ignition system. A mechanical vibration around 3000 ROM should also have a 2x frequency vibration around 6000.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-19-2024, 02:03 PM
Spark plugs , wires , cap, rotor, ignition grounds, sensors, micro switches , Barn door unit, injectors,
check and clean everything, go nuts , make a list , This process takes many hours !!!!!!!
Good luck
Ian
Old 03-19-2024, 04:21 PM
(man/dude)
Jonny042's Avatar
Does/did it change at all if the trans was in gear while stationary and revving? Could rule out input shaft/friction disc.
I'd change the friction disc it's easy to do at this point.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 03-19-2024, 06:28 PM
sithot's Avatar
Leak Down
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 03-20-2024, 11:00 AM
It's a 914 ...
Alan
If the pressure plate goes out of balance due to an overrev and causes a perceptible imbalance, you'll feel that all the time regardless of clutch engagement.
Old 03-20-2024, 11:53 AM
Thanks guys, I appreciate the input.
The motor and a fresh gearbox (LSD, HD side plate etc) have gone back in. New clutch installed but I didn't do the pressure plate (wish I had now!). Replacing rotor button and cap. Will let you know how it goes.
Kind regards Tom
Old 03-20-2024, 03:40 PM
My 3.6 powered car has a similar issue. I discovered it when mounting an old exhaust, and rediscovered it with my current exhaust. If my muffler is attached to the rear cross brace in the body, I get the same kind of vibration. My vibration is more significant on deceleration than it is on acceleration, but it’s there regardless. It’s also their standing still in neutral, revving, or holding the engine at RPM. If I simply disconnect the muffler from the cross brace and the body, no vibration whatsoever. Might be an experiment for you to run.
My engine is a 964 3.6 with no fluid damper, or harmonic balancer, with full headers, an exhaust, and a lightweight flywheel. I’m running Roth sport racing pulleys, hence the no harmonic balancer. I had literally no vibration until I attach the muffler to the cross brace and then it’s there. The card exhaust is Roth sport headers and a GT three muffler so it’s not like I’m using cheap parts lol
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-21-2024, 09:23 AM
