replacing door seals on 83 sc
Is there something special I should know about replacing the door seals on my sc?
Will they just pull out and push in? Is there glue involved.?
Thanks,
hughc
Old 04-11-2024, 11:55 AM
Hughc,
I simply pulled the old ones out, did a average effort of removal of adhesive from the channel.
Replaced with a 20$ uro seal, works great.
No glue for me, if it ever comes out of the channel I'll glue it in, but for now don't see any need.
Phil
81 SC.
930/16 (us model)
Old 04-11-2024, 12:38 PM
Originally Posted by ahh911 View Post
Hughc,
Phil
Thanks Phil, sounds simple enough.
I'll try it your way.
Cheers
Old 04-11-2024, 02:12 PM
PCA Member since 1988
I didn't use glue either, they have stayed in the channels. Easier to get them out "next time"!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-12-2024, 12:08 AM
I used a little double stick tape in the area i felt were going to lift
Old 04-12-2024, 05:51 AM
I'm good with tools.
AG81's Avatar
I just did my 72 and used Porsche seal. I tried two other brands and the door will not shut correctly, even after trying to adjust it. Maybe it's a long hood thing. As far as adhesive I needed a bit in the floor corners.... the rest stayed put and needed a bit of help due to new paint. for adhesive I used the yellow 3M 08001 Weatherstrip and Gasket Adhesive sparingly.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
02 996 4S (owned since new - heavily optioned)
Old 04-12-2024, 06:55 AM
