1988 3.2 Carrera How to safely remove electrical connector
See the picture, I need to pull the connector to get oil pressure before the first start up. Is there a trick to pulling these? I get worrried about working the connector too much and breaking it. I just wiggle the heck out of it and it comes loose after a while...
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 06-09-2024, 07:48 PM
I disconnect the plug for the injectors on the crossmember behind the heater blower motor.
206 637 4071
Old 06-09-2024, 10:26 PM
917_Langheck's Avatar
Remove the spring clip. Search junior timer connector.
To prime oil pressure you can remove fp fuse or the dme relay.
Old 06-09-2024, 10:40 PM
This! To me the easiest and fastest way to not start a 3.2. I even use this sometimes as a second (or third) anti-theft.
You can't see the plug but can easily reach it by feel. Just pull it straight up slightly and leave it in this position so you just have to push it back down once pressure has built up.
Gilles
RoW 88 Carrera coupé
Old 06-10-2024, 12:50 AM
famoroso's Avatar
I like the DME relay as a non-grimy (i.e. not reaching into the engine compartment) anti
-theft option.* I tend to unplug / plug the DME relay by "hugging" the base of driver's seat from the side. It's pretty easy to do by feel, at least under Pole Positions.
*I've thought it would be SUPER COOL if Focus 9 offered a "switched" version of their relay with a protected rocker switch on the top, as it would be easy to reach down and turn the DME on / off for any number of purposes.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 06-10-2024, 06:20 AM
Ctopher's Avatar
I agree and have communicated with them about the feature. They provided detail on how to make a kill switch, of which I have not done yet. Would make it easy to have a car alarm/kill switch but I mainly just pull the fuel pump to crank for oil pressure. I use this between long delays in drives.
CTopher
Old 06-10-2024, 06:37 AM
famoroso's Avatar
CTopher
Cool. Glad to hear that the idea is already out in the universal consciousness (it takes a village).
I appreciate that one can wire-in separate kill switches, but the coolness factor from one integrated into the DME relay would be hard to beat.
Frank Amoroso
Old 06-10-2024, 07:04 AM
Ctopher's Avatar
I totally agree! I would be willing to buy another for just that switch function!
CTopher
Old 06-10-2024, 05:32 PM
You could do it yourself. Just find a mini toggle switch and attach it through a hole made at the top of the plastic cover. On this picture, the pin I would cut is 85b. The current that flows through it should be small enough so you don't have to care about the current rating for the toggle switch.
I personally wouldn't do it because I don't find the position of the DME relay to be convenient for an everyday use kill switch. You still have to bend and partially remove the carpet that protects the relay and ECM connector, then reach to the switch at the top of the DME relay.
Gilles
Old 06-11-2024, 02:53 AM
famoroso's Avatar
Thanks Gilles. Cool to see the inside.
Mine are easier to access due to Pole Position seats and aftermarket floor mats (w/o the flap that covers the leading edges of the ECU & DME relay).
Frank Amoroso
Old 06-11-2024, 04:54 AM
I thought having a manual transmission alone is anti-theft enough in the 21st century when the kids don't even drive. Disconnecting the battery ground is the second layer of anti-theft. Unless the car thief is a Porsche owner, he would not know where the battery is.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-11-2024, 06:14 AM
If you have gone to the effort to add a rocker switch to the dme relay, you could add enough wire length to remote the switch to a place more accessible than the relay itself.
Old 06-11-2024, 06:54 AM
