Replace springs in pedal cluster?
I’m in the process of rebuilding my pedal cluster. The plastic bushings (esp. the two on the throttle linkage) were toast. Wondering if I should replace the springs? They look good, no rust, etc. I’m inclined to leave them under the theory of “if it ain’t broke …”. Anyone have an opinion on this? Thx!
Old 07-02-2024, 11:55 AM
(man/dude)
Jonny042's Avatar
As long as they aren't rusty - leave 'em. A properly designed spring doesn't "wear out". Otherwise we'd be changing out all kinds of things all the time, like torsion bars, etc. Only when they rust or suffer from some sort of wear that causes a stress riser should you be concerned.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 07-02-2024, 01:59 PM
Still here
pmax's Avatar
Just did the TBs.
If yours are as rust free, I certainly see no reason to replace these springs.
Old 07-02-2024, 05:29 PM
If you have the pedal cluster out and disassembled, I'd say replace the springs, you've already done 95% of the work.
1982 911SC
Old 07-03-2024, 06:16 AM
I agree. And springs can indeed wear out. My torsion bars were sagging on one side. I had a factory original torsion bar break on my 914.
Replacing the pedal springs is just a "while yer in there" thing that is good to do.
Old 07-03-2024, 07:06 AM
PCA Member since 1988
I agree with Jonny042. Well-designed springs don't wear out or fatigue, unless operated beyond their limits. The springs in my pedal cluster are 50 years old.
If a torsion bar breaks, it had a stress concentration point, probably due to corrosion.
Old 07-05-2024, 09:00 PM
Bland
unclebilly's Avatar
Ya know… this site has hundreds of tech articles on topics just like this.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/40-Pedal_Cluster_Rebuild/40-Pedal_Cluster_Rebuild.htm
Sure, they aren’t YouTube videos by a guy with a barely understandable Russian accent but they are clear and concise.
Old 07-06-2024, 02:36 PM
1979 911 SC
I don't see why you wouldn't replace the springs if you already have it apart. It's an inexpensive part and you'll be good for another 40 years. The rebuild of the pedal cluster was possibly the most satisfying project I have tackled yet in my novice wrenching hobby. there is a great article on the Joe Engineer website on how to do it. Was well worth the effort!
Old 07-06-2024, 02:49 PM
Thanks all. Even though one of the springs is apparently not available in the US and is currently on a slow boat from Bavaria, I decided to replace them both for peace of mind.
Old 07-06-2024, 07:45 PM
Originally Posted by turbofan View Post
I had the same dilemma when I was rebuilding my own pedal cluster. I ended up keeping the old springs because they looked fine and weren’t rusty. They’re still holding up well, so I’d say if yours look good, you should be fine leaving them as is. If you notice any issues later, you can always replace them then.
I can't remember why I was in there, but I was behind the pedal board some years back, everything looked fine except for some paint flaking on the cluster frame itself. Later that year the clutch spring blew out while driving. You never know!
1982 911SC
Old 07-08-2024, 05:32 AM
