Engine weights
Hey, gang. Anyone know the weights of a '74 2.7 and an '83 3.0? The 3.0 has no cat and, in fact, would be wearing the SSIs from the 2.7 when it goes in. A Pano article suggested the 3.0 would be heavier enough to warrant a change in torsion bars ...
M. |
The 3.0 with all cis devices on it and full exhaust weighs in at 438 pounds i'm told.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
My 2.7 bone stock weighed about 425.
Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
Below are wts. with citation. I asked Bruce Anderson & Jerry Woods the same T-bar question (but based on a 3.2L engine w/carbs in a '73). BA didn't change from his book. So I'm sure you could go with that.
- Randy kg lbs hp hp/lb Engine Years, Models Sources 184 406 130 0.320 2.0 S 911 1965 Aichle - 911 Engines 184 406 160 0.394360643 2.0 S 911S, 1967 Aichle - 911 Engines 182 401 180 0.448531061 2.2 911S Aichle - 911 Engines 182 401 190 0.473449453 2.4L S 911S, 1972-73 Aichle - 911 Engines; Tech. Spec. book, p. 103 - w/o oil 182 401 210 0.523286238 2.7L RS 911RS, 1972-73 Aichle - 911 Engines 200 441 175 0.396825397 2.7L "S" 1975-1977 Aichle - 911 Engines 452 2.7L 1977 weighed 175 386 2.7L 1975-1977 - 911S Tech. Spec. book, p. 88 - w/o oil 190 462 204 0.441558442 3.0L SC, 1980-82 Aichle - 911 Engines 190 419 3.0L SC w/ SSI & heat,w/o AC measured 219 482 231 0.479253112 3.2L Carerra, 1987 - 1988 Aichle - 911 Engines 211 465 3.6L 195 430 3.6L w/o any exhaust, w/o AC measured 238 525 250 0.476381029 3.6L 964 engine Frere, p. 97; Aichle - 911 Engines 232 512 285 0.557119399 3.6L 993 engine Frere, p. 97; Aichle - 911 Engines |
WOW. Thanks, Randy! just what I was looking for!
M. |
Here's a link to a thread that had a similar table:
http://forums.pelicanparts.com/showthread.php?threadid=99077&highlight=engine+weight+and+comparison
- '72 911T - '81 911SC Euro |
Not similar, I researched and posted it
Let me add some more trivia here -- a lot of the wt. is in the induction and exhaust systems (besides the crank & oil pump). But PAG used CAE for the 964 and esp. the 993 cranks (Aichle's engine book). So... if you put carbs on the engines, and SSI's -- the big engines (3.6L) may not be anywhere nearly as heavy as you might think. I've never weighed or torn down a 3.6L, but if anyone wants to ship me one, I'll get accurate wts. on all the components -- and will also see how well it runs in my '73 after a hotrodding -- at no charge!
So, Bill, as I read the charts (or try to, as it were), it looks like a '75-77 2.7 "S" (which is what my '74 Carrera has, except that '75 had airpumps) is between 441 lbs (Aichle) and 452 (actually weighed), and the '83 Euro 3.0 I'm putting in (930/10) is 419 lbs, w/SSIs & heat but w/o AC WEIGHED, and is also the weight stated by the "Tech Book." Do I have it straight?
Also, is there a way to actually weigh the engine when I get it out, short of taking it somewhere? M. |
I have always put the engine on a set of corner balance scales to get a weight.
The 930/10 will be very similar to my old 930/02 Which was measured at ~419# dry, w/ exhaust, intake, flywheel etc., w/o AC. The spec book also lists that 419# for the 930/10
Or put it in a truck or trailer, go to truck scales (free in Orygun) and eigh full & empty. Correct for whatever gas used if in truck. These scales are inspected regularly and will resolve to the nearest 20 lbs. (in Or.).
