Make sure that you adjust the ignition timing as specified for your engine. You got an 1982 SC IIRC ... RoW or US model?
I own a 1981 US spec SC with WebCam 20/21 camshafts which is somehow comparable to the 964 cams...I use an programmable 123ignition and adjusted the ignition advance curve as the Porsche workshop manual specified, even with 5° advance on lower than 500rpms amd 0° advance around 1200rpm to make engine start easier. See more on AndrewColognes page to the 930/16 engine: https://nineelevenheaven.wordpress.com/maintenance-of-the-distributor/ Porsche Workshop Manual: https://www.turbosition.com/_files/documents/Porsche_911_Workshop_Manual_1972-1981_EN.pdf This is my car on startup, sat for some days, did mot ran for some days, about 15°C ambient temp. https://youtu.be/ynJhhmi4TCM Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 11-17-2024 at 03:35 PM.. |
