Any body ever straightened a bent spindle?
I just got my '74 back together after a full teardown, rid of all rust, body mod's and paint. On initial setup I noticed a lot of negative camber on the front left. All other corners align good but I can't get less than -2.7* on the front left. I'm thinking I have a bent spindle on that strut. Anybody ever straightened one maybe with a jig and a press or forget it and search for a good one? Running Koni struts 3.5 spacing.
Thanks in advance to the knowledge base. - Kevin
A fair exchange is no robbery.
Not saying it's not possible, but I'd imagine a bent spindle would drive quite a gallop in your step. Does the wheel spin true off the ground? Any vibrations?
Behind the Sun
You sure is a bent spindle and not a bad front pan replacement?
I would start with a known perfect spindle. If you can't align it you know what is next. |
The wheel spins true and no vibrations. The very front of the pan was replaced but not the rear mounting points and a jig was used. those measurements checked out. Thanks for the reply, Kevin.
Maybe the spindle assembly has come loose on the strut, or the strut itself is bent, but those are Bilstein problems and I don't know if those apply on the Koni.
1982 911SC |
Pull the wheel and use a precision straightedge, thinking you have a bent spindle and having one are two different things.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Agree with David. I could see the spindle being knocked loose off the tube or the tube itself bending before the spindle being bent.
OK makes sense I'll tear it down and look more at the tube and the spindle connection. Thanks again for your thoughts.
It can be done but it's expensive. In my case it was a solid Dexter axle on a trailer. Whole axle had to come off, welded on. Warranty issue, Dexter was great BTW. Cheaper too with the warranty axle. I got my 3.5's from Chuck at ER, spendy. Check out the KW thread here for another option.
Elephant Racing welds gussets between the spindle and tube to prevent sagging of the spindle. Don't know if that can be done after-the-fact. Might want to mic the spindle journals to see if it would be worth the effort.
Reparations for neanderthals! '70 914-6, 1965 Mustang GT - RIP, '74 911, '01 Box S '12 Ducati 848 Evo - RIP, '16 Yamaha R1, '13 Aprilia RSV-R |
PCA Member since 1988
Bending of the front strut tube and spindle is not uncommon.
I had this problem on the passenger side of my car with the Boge front struts. The strut tube was bent, and I think the spindle was bent a little too. I was able to straighten it in my hydraulic press.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
how is your strut adjustment inside the trunk? there is no more room to open it??
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Straighten the tube and reinforce. If it bent once it'll bend again.
I had a friend kink a tube on a rally. It was three degrees of camber after the pothole and probably ten after he nursed it to the hotel that night. Needless to say it was trailered home.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
Possible to straighten, yes, with a press. You can measure left and right strut by measuring between brake disc and strut housing to check the difference or you have a problem elsewhere. It's pretty common for the struts to 'kink' or bend just above the spindle.
Thank you all for your help!
is it possible that your strut is bend?Look at the bottom ball joint space.The B.J. should be exactly in the center of the A arm..Take a picture and let`s see it
Ivan
There are so many things that can cause this, inner strut arm busing, bent tie rod end, bent strut.
Jack up car and move wheel side to side and top to bottom, to see if its loose. |
no |
