Stuck dust cap on front wheel hub!
1985 930 Turbo.
Front wheel hub dust cap on drivers side came off with minimal drama. Passenger side, not so much.
The dust caps are the style with a nut attached. I threaded a bolt into the nut, attached vice grips, and used a vice grip slide hammer to try and pull it out.
Nut came off the cap, cap didn't budge. I assume I'm drilling the cap and trying something else, but any particular ideas on how to get the cap off at this point?
2014 911 (991) Turbo S, Agate Grey
2008 911 (997) Turbo, GT Silver
2002 911 (996) Turbo, Polar Silver
2001 911 (996) Turbo, Arctic Silver
1985 911 (930) Turbo, Guards Red
Old 05-05-2025, 08:02 PM
Old 05-05-2025, 08:04 PM
Cory M's Avatar
Do you have a really big set of channel locks? If you do you can grab the cap and gently rock it back and forth. That usually gets them out.
Old 05-05-2025, 08:33 PM
My favorite dust cap trick: Get a u-bolt-style muffler clamp of the right size and clamp it to the dust cap. Use a pry bar against the hub surface to lever against the clamp. Work your way around the clamp and the dust cap comes off.
Old 05-05-2025, 08:46 PM
Weld another nut to it. Too deep to get anything to grab it otherwise.
206 637 4071
Old 05-05-2025, 09:28 PM
Not sure why the forum won't display the pictures I upload... let me try again.
Old 05-05-2025, 10:16 PM
There we go... As you can see, and as John Walker mentioned, it is recessed, no way you are grabbing it with any sort of tool.
I have a small 120V welder, but it's not nearby, I was hoping to avoid a several hour round trip to get it.
Damn it's in there tight! what about drilling a hole in the cap and maybe giving it another go with a hook style slide hammer?
Old 05-05-2025, 10:19 PM
Alan L's Avatar
That would work - if you had enough room behind it. But you probably don't.
Welding another nut would help. Clean the area up first to get a good weld.
It looks like quite a simple fix, just inconvenient.
If you drill it out to try the slide hammer, and fail, you may not have much room to weld the nut - so think ahead on that.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-06-2025, 12:45 AM
proporsche's Avatar
would this work? drill on each side hole-gently-after pry it out so you could grab it with fuller on sides...?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-06-2025, 01:09 AM
Drive to a shop that has a welder.
206 637 4071
Old 05-06-2025, 02:10 AM
Buy a $69 mig off Amazon with overnight shipping then throw it out after you weld the nut.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 05-06-2025, 05:46 AM
What about tapping a Zerg fitting and pumping some grease in to push it out? Just a random idea. Not sure if it’s open in the back or not to allow it to seal up. I used to use a similar trick to get old pilot bearings out in my other car.
Old 05-06-2025, 06:21 AM
'87 Targa
Where are you located? If in San Francisco area, I can come over with my MIG.
Lightly clean the rust, weld on a nut. Clean up properly once removed.
Don't drill anything. That risks hitting things on the back side, and shavings getting where you don't want them. ... IMO.
Old 05-06-2025, 07:20 AM
How about gripping it straight on with channel locks and tap at the channel lock with a hammer. Protect the cap with a rag or something
Bill
Old 05-06-2025, 07:57 AM
Thanks for all the ideas guys... Appreciated.
Sure enough, I can get a welder on my doorstep over night for $70. What a world! Considering it's like $25 in tolls and $25 in gas to go get my welder, not a bad option!
Heck, just a replacement OE Turbo style dust cap is nearly $100, so whats another $70! ;-)
Interesting thought... How much pressure can a grease-gun/zerk-fitting really create before giving up or just blowing the hose off the fitting?
. Thanks for the offer, but Colorado is a long drive from SF...
Old 05-06-2025, 08:33 AM
Once a nut is welded on, instead of a slide hammer, are there any pullers I can use that will pull on the inside and counter-act (push) on the outside?
All the various pullers I've used in the past pull on the outside and push on the inside...
Old 05-06-2025, 08:58 AM
So I received another suggestion off forum, any feedback on this one?
Drill a hole in the center of the cap. Install a M8 or M10 steel Rivnut. Thread a long bolt through the Rivnut, it will press on the spindle and (hopefully) drive the cap out without having to use a slide hammer...
Old 05-06-2025, 09:38 AM
Pfbz, that actually sounds like a good idea. The rivnut tool is probably more expensive.
Old 05-06-2025, 09:58 AM
Call A Mobile Welder Service……..
Keep It Simple. If you can not drive your car to a service shop, try to get a mobile welder service and have the NUT welded. You might as well have the other grease cup welded too.
Tony
Old 05-06-2025, 10:12 AM
As has already been mentioned, drilling a hole risks contaminating the hub grease with swarf. Probably the worst option.
Drive somewhere to get the nut welded or have a mobile welder come round to your house….already suggested above
Old 05-06-2025, 11:09 AM
