proporsche's Avatar
hmm the 930 cap has a lip ...did you try 2 screwdrivers and pry it out??
ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-06-2025, 11:19 AM
Originally Posted by Ian Comerford View Post
As has already been mentioned, drilling a hole risks contaminating the hub grease with swarf. Probably the worst option.
Drive somewhere to get the nut welded or have a mobile welder come round to your house….already suggested above
While I agree in concept, it's just the axle stub underneath there without anything really exposed until I pull the hub. And once free, the hub will have the old bearings and races driven out, fully cleaned, new bearings installed, etc. so I don't think contamination is an issue.
2014 911 (991) Turbo S, Agate Grey
2008 911 (997) Turbo, GT Silver
2002 911 (996) Turbo, Polar Silver
2001 911 (996) Turbo, Arctic Silver
1985 911 (930) Turbo, Guards Red
Old 05-07-2025, 10:40 AM
famoroso's Avatar
I really detest pulling those off with a slide hammer. It's so uncivilized.
I present a more elegant solution for a more civilized age...
Ridiculously laughably easy / gentle. A couple turns of the wrench and she slid out nice and easy. No drama. No busted-A$$ cap. No broken slide hammer chain / fitting. A Porsche nerd buddy and I put it together. He's a 964 guy, but don't hold that against him.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 05-08-2025, 04:09 PM
All's well that ends well!
Cap is off, parts through initial cleaning and (almost) ready for new races, bearings, seals, and rotors!
I appreciate all the comments, but the prize goes to @proporsche... I had never done front 930 bearings before, I assumed that with the nut welded on the cap, that was the best and proper way to remove them. But he was absolutely correct. Despite the nut and being fairly recessed into the hub, the dust cap DOES have a lip and I was able to get a small sacrificial screwdriver in the gap into the lip and start working the cap off. Thanks! (though I feel kind of stupid that the actual solution was so easy compared to welding or drilling or rivnuting)
Old 05-08-2025, 08:25 PM
proporsche's Avatar
pfbz:you are welcome...
Ivan
Old 05-09-2025, 07:10 AM
