Faulty rev counter
Hi
I have a 1994 3.2 911 target. The tachometer is faulty, as soon as you turn the key to the second position before it starts, the counter goes right round to 7000 rpm. When you start the car it does the same, when you stop the car the tachometer goes back down to 0. Any advice appreciated |
Pull the gauge and check the ground wires. Bad ground = pegs at max RPM.
Do any work in the frunk or adjacent gauges that might have pulled the ground out?
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
Bad ground will not peg the tach. If it pegs when power is applied, a component on the driver board has failed.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Whereabouts is the driver board located ?
Is it likely to be this as opposed to a faulty tach? hanks for the help |
update, i have unplugged the dme relay and then the dme, the problem with the tach is still there, goes right round the clock when the ignition is turned on and stays the same when started.
I have connected a volt meter to the black and purple wire at the back of the tach.
Ignition on its reading 12.4v Once started it drops to 10.8v and drops as the revs increase. I am not very technically minded so would be grateful of any input as to how it all works and any help to resolving the issue. |
When my 1978SC did this it was the voltage regulator failing allowing charging to rise to 18 volts. Suggest you measure output voltage of alternator. I did this by buying a plug-n voltmeter for the cigarette lighter.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
These tachs will work fine up to 20V, so your issue is more likely a damaged driver board, which could happen as a result of a bad regulator, so you want to check that before you repair the tach and put it back in.
Thanks for that help
I have just tested the power and gnd going into the tach and its 12.7v with ignition on and 14v running. Is this pointing to a faulty tach? |
could i try a generic cheap and cheerful rev counter before i send mine away to make sure thats the problem?
Sounds like your regulator is working fine. If you have 12V and the tach pegs with the purple/black wire disconnected, then it's definitely the tach. I wouldn't waste your money on a cheap tach to test it. You need to have it repaired.
