Which AC system do I have? '85 911 coupe
How can i tell which AC system I have? R12 or R134a?...or something else
I had AC work done years and years ago. Not sure if the system was changed from one to another. Now thinking of having the AC fixed AGAIN, probably a waste of money AGAIN, When asked what system is in the car and I dont know! How can I tell?? The photo is not the actual engine but is exactly like mine. More photos help? ![]() |
Original Denso compressor on this picture. Can't see the color of ports as they are on the hidden side on this pic. If black, probably original R12 gas. If red and blue, retrofitted to R134a.
Gilles RoW 88 Carrera coupé |
The Yellow/Orange sticker on the left with Charge Level tells you it is probably R12. There would be a new sticker somewhere showing the conversion to R134 if it was done right....
Suggest if you are having it "fixed" you make sure to change all hoses out, and maybe add more condensers... the hoses in these car leak like a pasta strainer.. check with Griffiths...
1986 Carrera 3.2 Coupe in Grand Prix White IG: @c.cal.porsche |
Look at the high and low side fill/discharge ports - `R12 ports are smaller and look like Schraeder valves. R134a ports are larger and resemble air hose fittings.
'80 SC Targa Avondale, Chicago, IL |
OK, thank you both
these labels?
these would tell me the type of system?
That bottom sticker is the one - looks like an R12 sticker....
It's not a waste of time to have your A/C fixed properly.
Using newer technology (e.g., parallel flow condensers) and other new parts as necessary, G-body cars are perfectly capable of producing fully-functional A/C, even in the hottest climates. |
sticker says R12 but may not be correct
my sticker does say R12, see photo, not sure if sticker is correct
Been here a while
that looks like the R134 cap tho....there should be a blue one, too. I suspect someone did a conversion, but they typically apply a decal stating the upgrade was performed.
looking for 1972 911t motor XR584, S/N 6121622 |
I do see the Blue cap underneath the hose
remove the red cap and you will know for sure what you go there..R12 and R34 have different fitting profile
Ivan
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
That's fond- just deglaze
Hi Jgurnari- here are the images of the R134A fittings with and without cap. My system was converted in 1998 by the previous owner.
Here's my overview of my rebuild of the system... https://forums.pelicanparts.com/porsche-911-technical-forum/930647-1986-c-repair-overview.html ![]() ![]() ![]() ![]()
Missed Approach Petra- 1986 Coupe Last edited by Missed Approach; 07-17-2025 at 06:58 PM.. |
A R134a converted stock factory AC system
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Great thread! If I may, i have the same stock system and it appears to still have the old refrigerant in it. This has caused an issue - I can’t find a shop that can discharge it due to their gear being used only for the new stuff and they don’t want any contamination. I would like to get the thing converted over and working but am blocked. Any tips?
1988 3.2 Carrera sunroof coupe “Rufus” (as in Parnelli Jones) 1974 Triumph Spitfire “The beast” 1974 VW Super Beetle Convertible “Zippy” 2014 Audi A5 S-line 6-sp “Lyle” |
Does the system work at all?
It likely has lost the refrigerant long ago as the factory did not use barrier hoses. The gas just leaked out and back then R-12 was 50 cents a can. Porsche decided to use the cheaper non barrier hoses, and save a few bucks per car. However you restore the system to operating make sure to add in a pressure switch. You can always buy a cheap set of gauges, and some auto parts stores have some you can borrow. Hook up the gauges, and see if there is any pressure. Just the low side (blue cap) will let you know if there is any refrigerant in the system..
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
blows warm
yes, the fans work but warm air. I can confirm the R134a system.
Just check the pressures with a set of gauges. If there is none, you have the perfect opportunity to get it functioning again. Contact Griffith's Technology and tell him what you want from your AC system. Replace all the rubber hoses, a new receiver-dryer, and any other components he recommends to get to your goal.
His instructions are so good that if you can change the oil on your 911, you can do it all with ease. Thee only technical part is evacuation and charging the system. Follow his advice on that. He makes top quality parts, and the best instructions you will ever read.
GH85Carrera. thanks
