Coram Deo
So solid continuity for the coil connections all the way back to the 6-pin connector. A to A, 31a to negative both show zero ohms. Evidently the damaged insulation and potential contact between the conductors was not the problem.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Dru,
The primary voltage from the CDI to the coil is up to 450V. At that level you might get arcing between the exposed conductors. A simple ohm meter reading won’t identify this.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Coram Deo
No exposed conductors at this point.
Agree, with the break in the coil wire insulation, the HV may well arc to ground ( e.g. any part of the engine metal or even the coil casing), rather than going through the coil. That could well have damaged the output stage of the electronics. Since you are a few miles away, I can share what to look for through our support so we can get this fixed for you.
www.classicretrofit.com Last edited by Jonny H; 08-15-2025 at 10:38 PM.. |
Coram Deo
Sometimes it take a while to remember things. Like the spare coil and CDI stashed in the smuggler's box just in case back when I had intermittent spark failure.
![]() And what do you know, it's a Bob Ashlock inspected (in 2013!) unit. ![]() Plug it in, and... ![]() So now on to the repair process for my broken parts. Thank you all for your help. I am now goin' mobile!
Since your spare CDI is a 6 pin and has not been rebuilt, it should be!
The 6 pin has a much higher failure rate than the 3 pin, because of a key component. Using it as a spare is risky, even though it runs the engine now. ![]()
Dave |
Thread Tools | |
Rate This Thread | |
