Bill Verburg's Avatar
Originally Posted by proporsche View Post
76fj55..i am not expert on those measurements Bill Verburg is -i believe the 8th+9th are 23,3..
Would have to remove the rims and look;-)
Ivan
all 944 Fuchs 8x16 are ET23.3, same as the 911 7x16, the 944 8 stretches the tire sidewall out .5" further on each side, the tread width is fixed so the sidewall stretch starts at 0 where the tread ends and ramps up to the full .5" at the wheel edge.
Never heard of a 944 5 spoke Fuch w/ a width of 9"
all 9x16, 5 spoke Fuchs are ET15, They were originally used on 930s
Proporsche's very nice red 911 is quite low and I suspect that several of the steps I outlined above have been implemented to achieve a trouble free fit.
The OP's white car appears to have Fuch 7 x16 ET23.3, so to reiterate, the 944 8 ET23.3 makes any tire fit worse.
While I like and use 8s on my very low 911, I use a wheel w/ a bigger ET, 8 ET27 or 28 is the best compromise between fit on the inside and outside w/ 8's
If a 7 is used ET24 -26 would be preferred to avoid the fitment issues discussed here.
But if you want to use Fuchs you are stock w/
6 ET36 or 7 ET23.3 available in 15 or 16 or 8 ET 23.3 available only in 16
There are 2 different 7 x16 ET23.3, a 911 part # and a 944 part #, They both fit exactly the same, the 944 version just has more caliper clearance and can be identified easily by the recessed lug holes on the front.
Bill Verburg
Old 08-30-2025, 04:57 AM
Registered Minimalist
75 911s's Avatar
The 205/55 makes it more challenging and can vary quite a bit with tire choice as already mentioned. I'm dealing with Pirelli P Zero on 15X7 Fuchs on my friend's 85. The 55 looks great but requires the car to be higher, significant negative front end camber, and rolled fenders edges.
MY 75 is about as low as you can get and I can still drive it practically without bottoming out on dips and obstacles - well except for that one huge rock that was hiding in the shadows! The 205/50 on a 15X6 looks pretty good albeit a bit small, but no rubbing and extremely low. I run three different tires and none of them catch the edge, even with my 245lb body weighing down the driver's side.
For the OP, I'd warm up the paint with a blow dryer or very carefully with a heat gun (far) and roll the edge with a bat, then I would raise the front maybe 1/2 turn on the height adjusters. That edge needs to be, at a minimum, rolled back to the stock height or say goodbye to that tire. It will keep catching that lip as noted.
You can see the transition point where I rolled it in this shot on my 75
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 08-30-2025, 05:31 AM
6x16 is a whole nother and easier install, it was after all an O.E fitment
205/55 on 6 x16ET36 has a tire front space of ~71mm compared to 7ET23.3 w/ a tire f/s of ~83mm much more lip room
The reason that performance minded folks want to use the 7 is performance, the tire works much better on the 7 and the track is a bit wider which is also good
205/50 on the 7 is shorter and gives much more room than the 205/55, my favorite 7 & 8 x16 Fuch fitment is 205/50 and 225/45
Bill Verburg
Old 08-30-2025, 08:21 AM
proporsche's Avatar
thanx Bill, my bad about the 9th;-) that tells you what do i know;-)?
Yes it took me one winter in and out of the garage to get to the point where it drives and handle perfect..still no rubbing -ever, on the fenders....
Ivan
1985 911 with original 501 587 miles...807 226 km
Old 08-30-2025, 08:22 AM
