Door plastic layer under upholstery
What is the purpose of the plastic layer under the door card? Is it important? Should it be repaired or replaced if damaged or missing?
Thanks in advance. |
Keeps the water vapors moisture from contacting the particle wood panel .
Your door panel will sag or deform over the years.
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
It's a vapor barrier. It often lost to the times but I would recommend keeping them if you have them (or even adding it back) as it protects the cardboard door car from getting wet and deteriorating.
Water from the window running down into the door will rot out the door card if you don’t have the plastic sheet to protect it.
In a perfect world, the door to window seal would prevent this, but alas the world isn’t perfect.
Rutager West 1977 911S Targa Chocolate Brown |
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Can these still be ordered?
I don't want to cheap out but have some of you found an alternative. I have found sheet of plastic but they are thin and lack substance. Thanks! Erik
1986 911 Coupe 1986 911 Targa |
Been here a while
I found porsche factory parts were readily available for the passengers side. Drivers side was 4x the cost.
One parts supplier had lovely self adhesive vinyl versions. But they shipped me passenger side only, too. I ended up using one as a pattern and cut some self adhesive shelf liner as an easy fix. Not too sticky, can be removed for access to the door hardware reinstalled at least a few times.
looking for 1972 911t motor XR584, S/N 6121622 |
Cut your own out of home depot thick plastic sheeting. You can attach it to the door with butyl tape.
Replace if ripped or missing.
Generally it can be mended if torn, most tapes don’t adhere to poly sheeting, Tyvek does. Why you need it - If your window rubber wiper seals have shrunk excessively (they all have some space in them) over the years, rain and wash water will flow down the openings at the ends, damage comes from water-soaked door cards, might even mold over if the foam anti-vibration strips on the door card gets wet, and if speaker cones are missing - they’re vulnerable to water damage as well, and not only that, debris will accumulate and block the door drain openings. Good to clean everything thing out. Once the door cards get wet repeatedly they will crumble from dry rot and maybe even forming mold if they stay wet and warm enough. The plastic in place also helps deaden a bit of the hollow sound too….I can’t hear my door ‘ping’ anymore. So it’s more beneficial to have this plastic covering than not. I found mine were missing from a hack job speaker install, door cards were watermark stained but held up w/o any warping. I replaced speaker cones with foam, self adhesive aftermarket type and for good measure put plastic sheet flap to cover them too. I used some 6 mil plastic drop cloth sheeting (probably the heaviest opaque sheeting available on the shelf) at Home Depot etc., with 10 mil being better. I cut out the pattern and used very tacky Tyvek tape to hold it in place. Even using Tyvek house wrap will work too. Butyl tape is good too, none at HD but I had tyvek tape readily available Note in my photo, a flap has to be cut and folded/tucked into the lower door void and just beyond the opening, this way any water running down will be directed back inside the door cavity and out the drain holes. - like flashing, it alleviates any chance water gets through and trapped between door card and the plastic sheet, the door sheet metal is stamped and there’s a lip around the upper and lower openings, it seems any water running down would be directed around the opening but looking at the OEM configuration, a slightly longer flap is present. I believe Pelican has the factory $$ or a generic $ precut sheets available. You just poke the holes where needed and fasten that lower flap. Butyl tape if you can find it by the metal roof section of Home Depot Menards etc. ![]() You can see where the water accumulates near the lower opening and speaker w/o the plastic in place
With the already ridiculous prices for air cooled parts and now the tariffs (which can exceed the value of the purchased item), I’d make my own.
Ass-engine Nazi slot car -- PJ O'Rourke |
Our host has them for $12, pre-cut (both sides): https://www.pelicanparts.com/More_Info/JWSTAPZDPMB.htm?pn=JWST-APZ-DPMB
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
Well, they’re from JWest (Texas) so one would assume that there will be no tariff. That said, if they are shipped from outside the country, I’d be hesitant. I bought a dash center vent from a Pelican in Canada for $40. Shipping/fees were around $13. Mid-shipment, I’m notified that I owe $42.37 in tariffs and additional fees. Mind you this is an imperfect used small plastic part for a 50 year old vehicle that will never be manufactured in the US (maybe URO) and the tariff was aver 100% of the value of the part. Even more infuriating, is US Customs documented in the invoice the value was $10.
Oh, and if they do go through US Customs, they will certainly be “pre-cut.”
Still here
Or use a material other than "particle board" for the door card ...
If you really want to see what cheap/lightweight looks like, check out some of the postwar economy offerings from domestic U.S brands. What you will find are heat/steam pressed fiberboard interior panels embossed with patterns that resemble leather or fabric then painted to match the actual upholstered items like the seats and armrests. They are very convincing visually, but pity the fool who tries to use Armor-All on this faux upholstery and ends up with soggy, stained cardboard!
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
Plastic Shower curtain from Wal-mart works great.
3m Trim Glue or Strip caulk can also be used to stick it to the door.
Great idea. I was heading to Home Depot or the likes...shower curtain never came to mind. Erik
You can buy vapor barrier from Home Depot as well. It’s used for siding and flooring
The plastic vapor barrier does more than preventing door card from getting wet. It also shields moisture from seeping into cabin when there's high humidity outside. If your car fogs up super quickly on rainy days, might be a good idea to check your moisture barrier to make sure its intact.
Home depot has everything you need to DIY replacement. Nice thing about the 911 is that the door is so flat. Makes it a simple DIY. |
A pair of AppBiz (now JWest) door moisture barriers ready to be unrolled...
![]() Door panel removed... ![]() XTC speaker baffle installed. www.amazon.com/dp/B0068AERWI Previous owner installed 6.5" aftermarket speakers... ![]() Applying the butyl tape around the perimeter of the door for the moisture barrier to adhere to... https://www.homedepot.com/pep/Gibraltar-Building-Products-50-ft-Butyl-Sealant-Tape-Roof-Accessory-in-Gray-99415/205945574 ![]() Moisture barrier installed and trimmed for my specific needs: speaker cutout, lock knob, etc... ![]() ![]() Door panel crack reinforced with some Gorilla tape. As an aside, I LOVE finding the handwritten numbers on these cars. Really speaks to the moment in time that they were built... ![]() Of course, when I went to reinstall the door panel, the rear hinge for the door pocket lid broke (as I was carrying the panel to the car), so a 24 hour JB Weld detour ensued... ![]() Panel hung, Sonderwerks aluminum release installed... ![]() Plastic trim piece on the leading edge of the garnish rail. They tend to crack. This one was intact, but I like to reinforce them by applying black foil tape to the backside prior to reinstallation...
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
