Sorry, my comment was to the stopper not the hole.
Old 12-16-2025, 09:25 AM
Sorry too. I misinterpreted your post.
Tony
Old 12-16-2025, 10:12 AM
Tony
It was my mistake for using "it." Using pronouns is just so risky these days!!!
Old 12-16-2025, 10:48 AM
Still here
pmax's Avatar
Originally Posted by BOPE View Post
Does anyone know of an alternative to the USD ~$60 fuel distributor stopper for a 1980 911 SC? The ~$60 price for a piece of wire with a small blob of rubber on the end just seems excessive.
So, I'm looking for less expensive alternatives, any ideas?
Does anyone know the diameter of the access hole? I may be able to make something if I know the diameter of the hole that needs to be sealed.
Thanks!
Jason
Air Flow Sensor not Fuel Distributor.
Old 12-16-2025, 11:05 AM
E Sully's Avatar
This thread is a lot bigger than the part it discusses. The hole is about the size of a 3/16" drill bit. 7/32" is too big to fit the hole.
Yes, the first CIS system had the plug. #39 in diagram for '73.5 PET.
911 110 934 00 Stopper for Adjusting screw. Same part # through 1980.
It seems in '81 when they went to O2 sensor and frequency valve they started using the tamper proof screw, which they recommend buying a new tamper proof screw.
There seems to be 2 places I ordered one from Classic DMC https://store.classicdmc.com/catalogsearch/result/?q=102392A
I did not have a lot of faith in DeLorean Go. When checking shipping, on half the choices they said not to use please choose the most expensive option.
Ed
1973.5 T
Old 12-16-2025, 02:01 PM
Yes, my mistake.
Jason
Old 12-16-2025, 03:10 PM
Still here
pmax's Avatar
Yes, my mistake.
Jason
When I first read the title, I thought it meant plugging one of the fuel ports in the FD.
Old 12-16-2025, 03:50 PM
E Sully's Avatar
I received the plugs today. They seem to be nicely made, but the flair on the end is a bit large for the hole. I don't want to push it too hard to get it in, as this might push the metal pin through the hard rubber stopper end. I'll give the tip a light sanding till it fits in snug.
I don't know how it will fit the later CIS with the tamper proof screw. From the photos of the DeLorean air plate, it seems they may have been the tamper proof screw type.
Ed
1973.5 T
Old 12-20-2025, 12:08 PM
Which one did you get? I ordered the one from the Delorean place in Texas. It arrives today.
Old 12-20-2025, 12:55 PM
E Sully's Avatar
The links is in post #25.
Classic DMC
Ed
1973.5 T
Old 12-20-2025, 12:59 PM
That's the one I ordered from too. Ok.
Old 12-20-2025, 01:17 PM
E Sully's Avatar
I was expecting a small envelope, but it was a large mailer containing a catalog and other advertising, including a few fabric swatches. Instructions say to use WD40 or silicone grease, but as I say it is a bit too tight.
Ed
1973.5 T
PCA Member since 1988
I sanded mine down a little to get it to fit more easily too. If it gets too stuck in place, you will pull the wire part out of the rubber part, so use silicon grease to prevent that.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-20-2025, 01:41 PM
Just arrived. Same issue.
I note that @Schulisco says the hole is 7 mm. Mine is 4.5 mm. But the second shoulder is just a tad over 7mm. I'm not sure this plug would work for his 7mm hole. I also note that the Delorean hole looks different. Could it be that the Porsche plug version is different?
Old 12-20-2025, 04:44 PM
Ok, I've been filing off the first lip. I think I'm going back to my first comment that I've heard the 73.5 didn't have these. Or the Porsche one is different.
But after getting off almost all of the first lip, adding a little lube, it fits very well.
At least it is suction. So it shouldn't come out. Hopefully there won't be any backfires, and if there are, that's what the pop off valve is for. But maybe it would be a good idea to add a safety wire to make sure the thing isn't lost by someone who takes it out.
Old 12-20-2025, 05:02 PM
