64E04132 1984 MY
wp0ab0916hs121755 1987 MY
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 Last edited by djpateman; 01-21-2014 at 03:49 AM.. |
My '77 930 Turbo has the following engine number: PS 1082001 does anybody knows whta it means?
Thanks,
http://917burger.blogspot.com |
It certainly is not a factory number. That probably means the engine was built using a new unstamped engine case. The engine builder then stamped his own serial number.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
86FlatSix
Hi, I was wondering if somebody could decode this. I have a friend overseas who recently acquired a non-running 1970 911 Targa and would like to know more about the VIN and engine
VIN - 9110210041 Engine 6200107 I am not familiar with early 911s. He wants to know if the engine on the car matches the year of the Targa. Last time car ran was 2002. Thanks JQ
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Car is targa 1970E and engine 1970 2.2E
86FlatSix
Wow, that was quick. Thanks Pors1968
Engine No. 93010191400
Also has this stamped on the side 901.105.111.1R Cheers.
Childhood dream car: Porsche 959 Last edited by willcall; 01-30-2014 at 07:27 PM.. |
Capitalist and Patriot
Willcall, that is not the engine number or type number. There are detailed directions where to find the correct numbers posted earlier in this thread.
Lower right side of engine fan will be engine number manually stamped on case with engine type (930-09 for example) behind it. Grab a flashlight and check them out and post back what you find. Also, model year helps as well if you have the chassis. Good luck |
I just joined and am astounded by the amount of knowledge and expertise on these boards. I am hoping someone could help me out with some specs and info on the following engine code:
*6116180* This is what I have deduced from other posts: 6 - 6cylinder 6180 - production # |
6116180 1971 911T-C zenith carb or weber 40idt
Thanks pors1968!
Sorry, my bad.
666908* |
911 Cabrio "Frankie"
Original Motor?
Hi Guys,
I'm Looking At Possibly Buying A '77 911 Targa. I Was Wondering If This Might Be The Original Motor? If Not What Exactly Is It? Vin# 9117210101 Build Date 08/76 Engine #'s 911/85 & 6270241 Thanks In Advance For Your Help
Another Engine Question....
Is This Motor A 2.7 Or A 3.0 ?
Owner Thought Car Had a '77 Carrera Motor Installed In The 90's Any Chance Of This Being A Carrera 3.0 Motor? Vin# 9117210101 Build Date 08/76 Engine #'s 911/85 & 6270241 Thanks In Advance For Your Help
83 911 Production Cab #10
According to the Red Book (not always 100% correct)
The body would be 77 911S Targa US The engine was fitted in a 77 911S (US) 911/85 is a 2.7 for US 50 state
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
case number ?
How about case # 3180259
68 L with sportmatic
Please decode my engine number
The engine code is 6451005
I think it's a '75 engine. It sits in a 1973 911T Thanks, Tom |
Well, let me try this again!
Engine number 6451005 Please decode this one for me. Thanks, Tom |
