Biff Bradley's Avatar
carrera intake manifold torque value
Can someone please tell me the correct torque value for my 1989 Carrera intake manifold allen bolts?
Thanks very much.
Biff
1989 Carrera Targa
(prev) 1999 Boxster
(prev) 1973 914 2.0
Old 09-06-2003, 08:32 AM
I don't have a specific # but when I did mine I did my best to tighten them just enough to squeeze the gaskets but not enough to strip the nuts.
Use your best judgement.
Cheers,
Joe
Old 09-06-2003, 02:23 PM
AS per the Bentley Service Manaul, on page 102-37 the torque
specs for the intake to cylinder head is 25nm or 18 ftlbs the same
figure for the heat exchanger by the way.
Keith Epperly 87 slant nose turbo look cabriolet "Carrera"
Old 09-07-2003, 09:12 AM
Thanks for the replies. Finally found it in Bentley. 10 of 12 were loose enough to turn with my finger. Might explain the hissing noise I was getting at high RPMs.
Just got finished extricating the valve adjustment blade I broke while doing the #4 intake this morning. That was fun. Now one of the tiny nuts on the tool is stripped, and I don't want to fish anything else out today. Can't find any loose valves, although the engine is ticking...
Biff
1989 Carrera Targa
(prev) 1999 Boxster
(prev) 1973 914 2.0
Old 09-07-2003, 10:23 AM
How may miles on your Carrera?
keith
Old 09-07-2003, 02:03 PM
18 ftlbs
ohhh yea!
Old 09-07-2003, 11:55 PM
52K miles. Put it back together and took it out after valve adjust, tightening intake manifold, and plugs. Seems to be running better, and quieter. Also found one plug that was not torqued down. I've had the car for about a year. Guess I should have checked this stuff earlier, but the car had a complete service history.
Biff
1989 Carrera Targa
(prev) 1999 Boxster
(prev) 1973 914 2.0
Old 09-08-2003, 05:36 AM
KTL KTL is offline
Schleprock
KTL's Avatar
These inhex nuts are notorious for coming loose.
I'd recommend putting spring/wave lock washers under the intake nuts to keep them snug. Blue Loctite might be a solution too? Split lock washers would work too, but would probably dig into the manifold.
Kevin L
'86 Carrera "Larry"
Old 09-08-2003, 06:40 AM
Send a message via ICQ to old_skul
Are those nuts easy to get to? 'Cause I think I'd like to retorque mine for safety's sake.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 09-08-2003, 07:35 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Not too many of them are easy to reach. You can see them. But getting your hex tool on them is another story. I had good success by cutting the bend off of a 8mm ball-end hex key. Now you have a straight piece of hex key that you can stick into a 8mm socket which lets you pivot it a bit because of the ball end.
Works quite well. Don't know how well it'll work with the engine still in the car though. I tightened mine while the engine was out. Might have to make your key a bit shorter than I did.
Kevin L
'86 Carrera "Larry"
Old 09-08-2003, 10:54 AM
I was able to reach all of them by removing the heater stuff on the left, and the entire airbox. Pretty easy. Had the A/C compressor off too, but I don't think that's necessary.
Biff
1989 Carrera Targa
(prev) 1999 Boxster
(prev) 1973 914 2.0
Old 09-08-2003, 11:54 AM
