Quick oil line question
I'm going to replace the slip-on oil line that comes out of the bottom of the oil tank and goes into the right side of the engine case on my 3.6L, where the oil cooler would be on a normal engine.
I bought a used oil tank and AN-16 lines and bungs - spendy! I'm going to weld the bung onto the oil tank and onto the oil line out of the case. Before I get started, do any of you see a reason why I shouldn't do this? Any caveats other than leakage, which I already have anyway? This is the oil line i'm replacing:
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
On my 3.2 914, I took the engine oil cooler off and had a AN-16 fitting installed onto the inlet side. Works great, no leaks.
It may be possible to weld/braze a fitting onto tank itself an then have a AN -16 fitting there too. Note, some folks use AN-20 lines in this application
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Should work fine, avoid the 90° elbows. As always bigger will have less restriction, but -16 on the suction line is fine. According to CM , who I believe the biggest restriction will be at the fittings anyway.
Well, tonight I welded the bung onto the tank.
The place where I bought the fittings only had -16 He looked in the cat and didn't see larger ones either, although they have to be out there *somewhere*. I guess if I'd really tried I could have avoided using 90-degree fittings, but it's too late now...
As an aside, I found 2 dipsticks in the new oil tank!
Now comes the trick of making sure you removed all the small metal pieces inside the tank.
SCWDP- Shock and Awe Dept
Thom, are you going to have a flexible connection on the other side?
I was thinking a rigid connection on both sides might not be the best idea. It seems to me that there would be some flex between the oil tank that is mounted to the chassis and the engine, very small amount of flex mind you but it wont take much very long to break something. Just wondering if you’ve thought about that and what you thing about it.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
I don't see a reason for concern - this is exactly how the two oil lines for the thermostat are set up.
It's good practice to put a bend in a flex hose to accomodate vibration. If the hose has to be straight, put a little "S" curve in it.
The hose won't stretch, it only bends. If the hose is straight, any linear motion tries to pull the hose out of the hose-end.
Chuck Moreland - elephantracing.com - vonnen.com |
The hoses to the thermostat have slight to extreme bends in them depending on vintage.
Thom,
A couple of suggestions ... 1. A Titanium-sheet heat shield between the exhaust system pipes and the new oil supply line ... the closesr to the exhaust the better! 2. A Teflon-stainless braided hose would seem more suitable for that particular supply hose in close proximity to the exhaust ... Aeroquip makes hose and steel fittings in the AN-16 size. They also make a gentle-radius steel 90° bend with male fitting on one end and female swivel fitting on the other ... that would seem perfect to get past the area that caused your big leak with the previous hose.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs Last edited by widebody911; 09-30-2003 at 11:27 AM.. |
My plan for that line is to use a stock S hose(already there) w/ an insulator)not done yet) as suggested by Warren.
Here is a site that has some potentially good insulators
Royal Brass in San Jose, has all the steel fittings in AN-16 you could possibly need.
Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
http://www.stockcarproducts.com/aqp1.htm by the roll or by the foot. I have also used these clamps: http://www.bakerprecision.com/earls21.htm Last edited by Embs; 09-30-2003 at 06:00 PM.. |
