Keith, Kevin, Will...
You guys are awesome! Thanks so much for your informative, all encompasing posts and links on the G50 shifty
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Just replaced my shift bushings and O-rings last month..the rear bushings were fine! Now she's a new shifter COMPLETELY...no more clunks!!! quite tight (stiff, a bit,..but settling in quite nicely)...shouldn't have to go back in there for a while.
Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
the wevo g-50 shifter and wevo PSJ have been installed. no longer does 5th gear seem out in right field. no longer do i have 5th to 2nd shift grinds. entire new feel to the car. best example is putting your hand on a high dollar custom .45 and pulling the slide back for the first time in comparison to an outta the box basic G.I. grunt model .45. wayyyyyyy shorter shift throw and precision positive shifting. well worth the money. this may be biased since my oem shifter was trashed internally and needed everything under the sun to revive back to stock. and the coolest thing about spending these hard earned bucks unlike other bucks thrown at car.................YOU CAN ACTUALLY SEE IT AND FEEL IT EVERY DAY! this was well worth it. very happy with the change. wevo makes some damn good products. hooked up with their motor mounts and patrick motos tranny mounts the shifting cant get any better! wevo now offers a taller shift knob, probably going to order one here. im 6"3" and this will be the ticket to even smoother shifts. |
I plan on doing the G50 bushing repair this weekend.
Can someone explain the 5 mm adjustment of the base of the shifter?
Dave K |
The new kit actually comes with a nifty tool that is 5mm wide and makes the install super easy. https://www.jwestengineering.com/G50-Bushing-Kit_p_26.html The instructions show how to use this tool to get it all setup. https://www.jwestengineering.com/assets/images/Instructions/G50_bushing_install.pdf I had to do it with a thick screwdriver that was approx 5mm to get the spacing right. -Ian |
http://forums.pelicanparts.com/porsche-911-technical-forum/1147747-its-baaack-2023-jwest-rennshift-87-89-g50-911-a.html
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Frank- Thanks Perfect! Exactly what I needed.
Dave K |
Schleprock
20 year old thread is still generating requests for the Excellence article…….. wow
I’m clearly getting old and been on this forum too long! gdp_samson, you have an email coming your way
Kevin L '86 Carrera "Larry" |
I may have a spare, with JWest coupler installed.
