Nigel's right.
Home Depot is the place. They even have the blanks (for my '77). Not "Porsche" mind you, but they work for spares. I suspect keys and locks for the mid years (70's) are easily duplicated and changed. Don't know about the 80's models.
If it doesn't leak, you're out of oil. If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt. Screw Flanders.... I'm goin' to Moe's. |
Thanks for all of the input!! It sounds like Home Depot is the place! Not even 5 minutes from my house!! I'll post the results Monday
Dean 1978 SC Targa Euro 1966 911 Coupe Restored/Burned/Sold - In that Order |
Author of "101 Projects"
We must have sold thousands of these Porsche key blanks:
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?command=DWsearch&description=key+blank and I've never heard of anyone having a problem getting them cut? Try Home Depot? -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
The problems I've seen with key cutters is that the steel Porsche keys are supposed to be cut with a special carbide cutter that most locksmiths don't have. Most keys, including the replica Porsche keys are made of soft brass. If you find someone who doesn't know this (i.e. Home Depot) they may cut it for without knowing they will destroy their cutting wheel, like cutting through nails with a Skilsaw blade. The other and more significant problem is that some if these guys don't know how to cut the double sided key properly (and this I would not trust my expensive Porsche blank to Home Depot) Single sided keys are easy because the master and new blank have a flat side to base against on the machine before cutting. Not so with a double sided Porsche key. If either the master or blank are not exactly centered in the jig, and when flipping over the copy to cut the other side, the distance of the groves from center will off - I've seen it happen several times. Even the master locksmith I've used here in L.A., Via Zapata, notes that he has to use extreme precision when cutting the blanks. So I'd make sure the guy you use knows what he is doing.
Stuart at sales@keys4classics.com can cut from codes if you need that. He also has the very hard to find wheel lock key blanks or again he can cut those from code.
I'd get your 'normal' blanks from Pelican, reasonable price, and the 'real deal'.
'04 BMW R1100S BCR '01 Audi TT RS gone but not forgotten: '87 911 Carrera '59 356 Coupe '66 912 Speedster '99 996 Ducati |
Canadian Member
I got a pair of these from our host....
locksmith in town cut them, no problem. Now if I could just find them?
In the SoCal area i would go to steve's lock n' safe, across the street from manhattan beach mall, on sepulveda. Talk to dave, he's actually the owner and my father. I worked for him during summers and those keys are a pain because of the fact that when you flip it over it can be out of alignment and if you dont measure 3 times then you will sometimes mess one up. Also anyone looking for an alarm install, you might want to check the shop out, never had a car stolen in 25 years of installing alarms (NO BS). His alarms are not cheap because of the time he spends installing them, but your not investing in a noise maker.
You didn't crash, you just ran out of talent. Mike Stapleton |
'89cab,
I also bought blank keys on line and went to the locksmith on Del monte around that japanese place at the intersection of Broadway in Seaside. No problem. I gave my original, the blank key, made me a copy and charge only $2.00 for labor. Phil. |
canna change law physics
Geez, when Wayne's (former) SC didn't have any keys, I called a mobil key smith who cut the keys from the key numbers I found in the owner's manual.
Sure beat driving around with a screwdriver...
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Virginia Rocks!
Yeeehaw!I hope you have better luck with your dealer.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Steve was that from randell? If so he had ALOT of porsche's to go through
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
If you have AAA, call AAA and have them send a mobil locksmith...
Virginia Rocks!
I've had bad luck with Home Depot. Two seperate house keys and many trips back and forth. I finally gave up.
I went to a very well equipped local locksmith who charged a bit more but the keys worked perfectly the first time.
Warren & Ron, may you rest in Peace. |
BTW, here's Tony the Key guys website (as previously mentioned)... http://www.hillmanimages.com/912/030601-2338.html
Bring/send him your Pelican blanks and you're in business.
Senior Member
If I were a locksmith, I'd either get out of the business, or get a machine that performs well enough to cut steel keys. Ridiculous. I guess they're ready to cut plastic keys any time you like.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
