H.G.P.'s Avatar
Advise me the inexperienced on "redline" technicals.....early 911
I'm not that experienced with the understanding of the "redline". The redline on my tach is 7000. Is this something I should:
1. Stay below at all times?
2. Unsafe at certain gears?
3. What is the max, speed per gear (5 speed here), that I should have on my 911 E for each gear?
4. And is there an ideal shift speed through each of the gears, or is this a function of RPMs?
Thanks.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 03-13-2004, 02:51 PM
Gon fix it with me hammer
svandamme's Avatar
1 yes please do not go above.
2 revvs is revvs. doesn't matter what gear you make em in for the engine..
3 dunno
4 you want to keep your engine in the best part of it's power/torque curve for sporty driving but that usually is something you feel while driving... you could go all scientifical about it and have the car tested on a dyno to know what your cars curve is since it's probably not the same curve as when it left the factory.. but i'de say that's a bit over the top...
Stijn Vanbeselaere (ex Vandamme)
EX911STARGA73EX92477EX94484EX944S88EX987C2007LOOKINGFOR|987C2009|981C2016
BIMDIESELBMW116D2019
Old 03-13-2004, 02:57 PM
lateapex911's Avatar
NEVER go over redline.....and if you are driving the original engine, it might be a good idea to be conservative.
And be careful downshifting, if you aren't at the right revs in the higher gear you can drive the engine over redline mechanically, which is just as bad as doing it with the throttle!
And don't miss the 3-4 shift by going 3-2...Ooops! $$$$
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 03-13-2004, 03:03 PM
H.G.P.'s Avatar
OK!...
And so the "redline 7000" that is the "warning mark", "danger mark"?
1969 911 E Coupe
Old 03-13-2004, 04:16 PM
svandamme's Avatar
that's the "do not cross mark"
Old 03-13-2004, 04:24 PM
Not 'warning', not 'danger' mark-- kaputt mark.
Beethoven
'88 911 Coupe
H.G.P.'s Avatar
OK. Thanks...(hope I haven't accidentally done anything to the engine in the past.)
1969 911 E Coupe
Old 03-13-2004, 04:28 PM
svandamme's Avatar
you would notice pretty fast
it turns your pistons into this
read all about it
http://forums.pelicanparts.com/showthread.php?threadid=113368&highlight=engine+blown
Old 03-13-2004, 04:31 PM
pwd72s's Avatar
Ahhh Hell! Just drive the krap out of her...when she blows, she blows! "There she blows!"... (Apologies to Monica)
Old 03-13-2004, 05:18 PM
3.2 CAB's Avatar
If you have a motronic 3.2, you will never see the "red line" unless you, or someone else has altered it beyond specs. Can't really answer for you though, a lot of people state their car year, but not the engine. I usually figure if it is 20 yrs old it might have the same plant.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-13-2004, 07:15 PM
H.G.P.'s Avatar
This is the original matching no. 911E 2.0 , with 901 trans.
1969 911 E Coupe
Old 03-13-2004, 07:43 PM
