sundaypunch's Avatar
I had the same problem after a caliper rebuild. You want the pistons to be pushed up tight to the pads prior to bleeding. Use a spacer thinner than the pads and pump the brakes to allow the piston to move forward a bit. Force the pads back in and bleed. Without doing this you'll never get a good pedal.
The $45 for a Motive bleeder is money well spent. I wouldn't waste any more time (and $$ Super Blue) bleeding the way you are currently doing.
Old 05-03-2004, 06:45 AM
na2ub's Avatar
Originally posted by Paulbav
... if i really pump the pedal it does get some pressure and if I move the car it will stop when pressing the pedal just not any where near as good as it should!! so I guess that the calipers are moving??
Paul
Paul,
I have read on this board that it is possible to damage the Master Cylinder seals by bleeding by foot, by extending the pedal travel more that driving conditions would do. I suppose that if the seals have been damaged, you should be able to build pressure with the pedal, but when you keep your foot on the pedal, you would be able to feel it losing system pressure, as the fluid leaked past the seals. Could this be your problem?
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
addictionMS's Avatar
two tihings,
did you bleed the inside nipple on the rear calipers, often missed
plus, rebuilt caliper seals will sometime take time to seat, the seal is so good that the calpiers get pulled back into the housing some and the pedal feels soft for a while. One reaon never to re-build all the calipers at once, but rather do the fronts one week then do the rears the next week.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 05-03-2004, 08:28 AM
beepbeep's Avatar
Pushing on pedal too far when bleeding brakes can damage the rubber gaskets in Master Brake Cylinder...they will travel much further then usual and get ripped and hemmorage brake-fluid internally.
There is certain possibility you did just that...tap on MBC and all calipers to dislodge eventuall air-bubbles, re-bleed and try again. If you still have the problem I suggest you to dissassemble MBC and change gaskets.
Thank you for your time,
Old 05-03-2004, 08:49 AM
Paulbav's Avatar
THEY WORK!! I have fixed my brakes at last have to admit though it was a bit of user error, it turns out that when I had the calipers off to clean and paint them I got them mixed up and accidently put them back onto the wrong sides of the car Doh! so after 2 days of trying to bleed them I have sorted it in under 2 hours!!. Thanx for all the input from everyone but look as if it's a roll over as there was no winner this time we will just have wait and see what I f@#k up next and see if anyone can guess it right!!.
1990 944S2
(Gone to a new home)
1989 911 3.2 Carrera sport
slate grey
Old 05-04-2004, 12:34 PM
a member profile in your signature location will aid in diagnosis ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-04-2004, 01:51 PM
Paulbav's Avatar
A what in where???
Paul
1990 944S2
slate grey
Old 05-04-2004, 02:15 PM
350HP930's Avatar
Yes, bleeder screws work a lot better when they are at the top of the caliper.
Old 05-04-2004, 03:18 PM
A what in where???
Hey Paul..
any coconut trees, or whatever you call them, in the south coast.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-04-2004, 07:17 PM
one of gods prototypes
bell's Avatar
ron you even confused me with that one...............but a swallow could've carried it
Brought to you by Carl's Jr.
Old 05-04-2004, 08:58 PM
Paulbav's Avatar
Hey Paul..
No coconut trees just a ropey lookin palm tree in my front garden and ur run of the mill ye olde english oaks!
1990 944S2
slate grey
Old 05-05-2004, 10:47 AM
Paulbav's Avatar
Wow that was my 100th post!
1990 944S2
slate grey
Old 05-05-2004, 10:49 AM
