CV Joint bolts from McMaster Carr?
Didn't someone recently post information about buying the CV Joint bolts from McMaster?
If anyone remembers the link or the part no from mcmaster, please let me know.
Thanks,
Brian Keith Smith
briankeithsmith@ctc.net
Brian Keith Smith
Old 07-11-2004, 07:22 PM
jbripps's Avatar
Hi Brian,
How funny is that? This is my first time visiting the board in 5 days or so, and I see your post. I recently used MMCC, they are great. I had to buy the 45mm cv bolts to replace the factory axle. Are you looking for a set? I have a load of them.
Here is the link:
http://www.metricmcc.com
Regards,
Jon
'85 Targa (recently acquired by Coollx)
'02 Carrera 4S (holy moly...I'm in heaven....in the snow too)
'06 BMW 325i (gone and forgotten)
'03 Honda Odyssey (more dings every day....thanks wifey)
Old 07-11-2004, 07:31 PM
I need 60mm ones for my 911 Turbo.
I know I need M8's 60mm long, just not sure what pitch for the thread?
1.5?
Brian
Brian Keith Smith
Old 07-11-2004, 07:33 PM
fancytown
Standard "coarse" thread for a M8, I believe, is 1.25mm pitch.
all cars sold.
Old 07-11-2004, 08:39 PM
Irrationally exuberant
ChrisBennet's Avatar
1.5?
Brian
Better check, Turbos use M10x1.5 (not 8x1.25) don't they? I think the grade is 10.9. I know the grade is greater than 8.8.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-11-2004, 09:00 PM
911 CV joint screws are class 12.9.
Old 07-11-2004, 10:43 PM
Binge User
Schrup's Avatar
I would order some serrated Schnorr washers along with the bolts.
Paul
Old 07-12-2004, 04:32 AM
304065's Avatar
I ordered the bolts from McMaster-Carr. They come with a blue oxide finish (don't think that affects the torque value) and are labeled "CAMCAR." Camcar is a fastener subsidiary of Textron Corp.
The quality (at least visually) was OK, the coating fairly consistent.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-12-2004, 05:14 AM
I believe Chris is correct as we just went through this on a friend's wide body...like the Turbo they use 10mm bolts.
Don't go by looks or finish....look at the top of the head indicating grade ( 10.9, 12.9, etc).
Alternate sources include MSC and Graingers...as far as industrial supply houses go.
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-12-2004, 05:43 AM
jbripps's Avatar
If you will be referring to Wayne's 101 projects, the torque they suggest is wrong. For your bolts, I think the actual number should be 60 or 61 ft. lbs. for the 10mm. The numbers he uses are reversed.
Ask me how I know. Hey Wayne, can I get a credit when the second edition comes out? I snapped a bolt due to attempting to torque the 8mm bolt at 60 lbs.!! I think the error has already been reported to you. A credit would be very prestigious for me...haha.
regards,
Jon
Old 07-12-2004, 07:28 AM
Correct..the nominal 60 ft-lbs is for the larger 10mm bolts. I think the 8's use 30-35 ft-lbs, if I recall correctly.
---Wil
Wil Ferch
Old 07-12-2004, 07:48 AM
billyboy's Avatar
Mc Master-Carr and this place:http://www.metricmcc.com/ are two different places. I do know that everything(tons) that I have bought from McMaster-Carr is is first class.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 07-12-2004, 08:30 AM
regards,
You're about two years too late; see the below errata link.
http://www.101projects.com/Porsche-101/corrections.htm
Jim
Old 07-12-2004, 09:23 AM
Randy Webb's Avatar
What is the advantage of getting them from MCC or McMaster-Carr as opposed to the dealer? Are they really so expensive there that it pays to mail order them?
Old 07-12-2004, 10:46 AM
The dealer is way more expensive and the dealer ones have the triple square head which is inconvenient.
-Chris
Old 07-12-2004, 11:22 AM
jbripps's Avatar
At MMCC, my box of 50 bolts (8mm x 45mm length) was $14.00. I thought that was a deal. I picked the box up, but they had it shipped to them overnight from one of their other warehouses, and did NOT charge me extra. I thought that was great of them, and will go back again and again.
Regards,
Jon
Old 07-12-2004, 11:33 AM
304065's Avatar
Actually, I just got two bags of OEM porsche bolts from our host here and they had a Hex head.
For sale, 16 hex-head bolts, 10x48mm, $24. I will pay shipping in USA. First to respond by private message gets bolts, payment by Paypal only.
'81 R65
Old 07-12-2004, 01:52 PM
Randy Webb's Avatar
I got the hex heads from the dealer. I used the 50% off coupon, but it appears Dr. Wienie King has put a stop to that in favor of keeping the yuppiie's purchases pure.
Old 07-12-2004, 03:00 PM
the gaskets are a pia when using 30lbft. I left them out 2mo ago and used some realy sticky axle grease on the mating. I want to drive on the beach at low tide to test my latest bright idea.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-12-2004, 03:35 PM
North Coast Cab's Avatar
I used McMaster Carr bolts when I repacked this winter. I've had 6 track days this year and I checked torque before each event. Zero problems or issues. Way cheaper then factory and easier for me to get.
John
1985.5 944 GTS
Old 07-12-2004, 05:35 PM
