david.avery's Avatar
I just found goingsuperfast on ebay, header is stuck at $800, looks nice.
ANother pelican who was doing an SC kit (rfng) was ramping production for all of the tubing and custom fab stuff, but he's disappeared
I still maintain, $3500-$4K worth of stuff to make this car a real tiger would be very worth it.
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 08-02-2004, 07:47 AM
Actually I don't think he even got started on 3.2 stuff. Seems GoingSuperFast is filling a much sought after niche.
Warren & Ron, may you rest in Peace.
Old 08-02-2004, 09:15 AM
Keep me updated, I am so happy!
Old 08-02-2004, 09:28 AM
Im not trying to dampen anyones spirits but you pay for what you get
With my 3.2 turbo Mt motor runs great but my trans and clutch are Starting to go motor mounts, trans mounts oh those headers on ebay 304ss they will crack and the intercooler is only as good as it flows.
Old 08-02-2004, 09:41 AM
Yeah, make sure when shopping it flows better than the factory 930 intercooler....which shouldn't be too hard.
Old 08-02-2004, 10:22 AM
the Promotive intercooler looks incredible but it costs what l have into my entire system.l guess if l really start adding up the supporting mods l`d be into some serious money.l have less then 1000 miles on a new clutch/lightweight flywheel and rebuilt trans. Also just did full complete autocross suspension ungrade all around and big brake conversion. l had solid motor and trans mounts but took them out because l hated the noise/vibration. The "goingsuperfast" headers are made by the same guys who do B&B`s headers. l just bought a B&B set and they look identical to the superfast but mine have the heatboxes so unless the metal is different they should last just fine..
my life begins at 150MPH
Old 08-02-2004, 01:13 PM
WydRyd's Avatar
raceman, you are taking the correct route to "HP heaven". Trust me, you won't look back once it's all in and running. The only problem with these conversions is that you WILL want more and more. BTDT
Your "saving grace" is that Intercooler. As long as you are above 70% efficiency, you'll be OK at that compression ratio @ 0.7bar. The factory 930 unit only runs at ~14% efficiency, but I guess at that C/R and relatively low boost of 0.8bar, it doesn't need to be much more than that. It's only when you start running big boost where you need a more efficient IC.
Keep us posted on your developments. It should be a nice setup with those headers
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-02-2004, 03:59 PM
Unconstitutional Patriot
turbo6bar's Avatar
14% efficiency? Are you sure? That's truly pathetic. A drunk man urinating on the intake pipe would generate 14% efficiency. Sheesh!!!
Jürgen
Old 08-02-2004, 05:52 PM
WydRyd's Avatar
Yup, that's the efficiency those run at! Have a look in Bruce Anderson's Performance Handbook. Truely shocking! Might as well not have an IC at that efficiency
Merv
'89 911 Turbo Cab
Old 08-02-2004, 07:36 PM
dickster's Avatar
raceman, yeah, it was the cutting and welding that put me off. i can weld mild steel but i think i would make a mess of the project.
the proto kits start at $5k so it will be interesting to see how yours compares.
i look forward to seeing it progress.
Rich
'86 coupe
"there you are"
Old 08-03-2004, 04:42 AM
Jürgen
Better than I thought. I heard from a few sources it was 13%
Race: Can hardly wait for those detailed pics.
Old 08-03-2004, 05:40 AM
Original Owner
tsuter's Avatar
Don't need no stinkin intercooler for apps under 8.5 CR and 9psi and the right fuel.
Pump it up!!!
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 08-03-2004, 05:58 AM
Lots of cheap intercoolers on ebay, perhaps they could be adapted. Ricers love nothing more than an intercooler, and when they smash up their 350hp civic, the first thing they dump is the turbo components
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7913411079&category=33742
David Avery
Old 08-03-2004, 06:29 AM
WydRyd's Avatar
Be very careful! I wouldn't settle for anything less than a full length Intercooler for your configuration. You'll need every cubic inch you can fit under that tail to keep the intake charge as low as possible at that compression ratio and boost pressure. How's 29" x 10" x 3.5" sound?
Merv
'89 911 Turbo Cab
Old 08-03-2004, 02:52 PM
Unregistered
sammyg2's Avatar
I would advise against trying to drain into the valve cover.
The longer the run the lower you need to go, plus the G forces would push the oil back in the line towards the turbo, ask me how I know. Big smoke cloud.
Drain back into the lowest corner of the chain tensioner cover, that will work.
Old 08-03-2004, 05:54 PM
Update on RFNG's SC turbo, elsewhere on pelican.
He abandonded the project, said there wasn't enough interest. Sad to see that development stop
but... I love this thread! I'd love to see you'all develop a spec/manual (people would even pay for it, I would!) towards turboing a 3.2.
David Avery
Old 08-03-2004, 06:44 PM
Raceman,
i too bought the header from the Goingsuperfast guy.(back-doored the ebay auction)
i spoke with him and he explained that the header is in fact from the same co. that makes the B&B units.
here is his email to me just today actually....
"I have the same company who makes B&B header for me and I have a intercooler company build the intercooler for me . I'm not a good welder.
I have 7 - 8 machine shop and muffler company to work with.
This factory makes the header for Boxster, 993 and 996."
anyway,
ive never heard of 304 SS cracking...maybe with the weight of a turbo on it without a actual support.
though nicely built, i do not care for the way the two sides of the headers connect though.... i think ill add a pair of flanges there myself.
in all, the workmanship is quite impressive for $850.00
Old 08-03-2004, 06:51 PM
WydRyd's Avatar
Maybe only the headers with the heat exchangers around it cracks, due to the heat over a prolonged period?
IMO, you don't even need "turbo" headers. I'm running the factory heat exchangers with a "J" pipe bolted to it which interfaces to the turbocharger. It's an "on-the-side" system, meaning, the turbo sits beside the engine next to the #1 and #2 cylinder. At that C/R and boost pressure, you hardly notice any lag. Full boost by 3.5k and pre-boost driveability is like any naturally aspirated 3.2 It's not the ideal turbo header system, but if you are doing this on a budget, that's the cheapest way. The J pipe would cost you about $300, or even LESS if you have some welding skillz
david.avery, the bolt-on capability of these turbo kits for the 3.2 wouldn't be possible without the extensive R&D Protomotive put into developing the Motronic CHIP's fuel & ignitions maps and their rising rate boost sensitive fuel pressure regulator. Without it, you would have to rip out the whole Motronic system and purchase an aftermarket Engine Management System. Then it wouldn't be a true "bolt-on" system and would cost significantly more to setup
Merv
'89 911 Turbo Cab
Old 08-03-2004, 08:17 PM
dickster's Avatar
merv, are you still running the J pipe on stage 3?
i was looking at the "on the side" kit from proto as its the cheapest way to start out (and very simple) but didnt think that would be a good basis for future upgrades?
Rich
'86 coupe
"there you are"
Old 08-03-2004, 10:12 PM
WydRyd, thanks for the note... from what I've read, I would definitely go with their chip and regulator.
The question in my mind is whether it would be better to sell my engine & DME for $4500-5000 and go 3.6 (which I've done two 911's ago). Figure 7500 for the motor and 2500 for parts = approx 5K outlay.
Ideally, I would like to put out no more than $3500 and treat this as a winter project. I'll keep an eye on this one closely
David Avery
Old 08-04-2004, 05:03 AM
