Power Window Switch Wiring
I'm one of those guys who doesn't listen to good advice and gets humbled by it every time.
I recently removed the door panel from a 1986 Carrera and, despite the suggestion, didn't write down the wire-to-terminal information.
Can anyone help me with deciphering which wire goes where on the numbered terminals for both the driver and passenger window switches?
Old 09-27-2004, 03:07 AM
DJB DJB is offline
DJB's Avatar
Davy, I also have an 86 and here are some photos I recently took prior to a disassemble - hope they help. BTW mine is Right Hand Drive,
Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module
997 C4 Cabriolet - Basalt Black
86 Turbo Body 911 Cab - Many Mods
Gone and Missed:
97 993TT: PSS9, CarGraphic Exhaust
Old 09-27-2004, 04:11 AM
DJB DJB is offline
DJB's Avatar
and some more...
all back together....
Gone and Missed:
Old 09-27-2004, 04:13 AM
Dave... those are great pics.. how did you do that ?
ps: only about 4 full size pics under 100kb total
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-27-2004, 05:50 AM
David:
Thank you very much for the pictures! They were exactly what I needed to make the connections.
The following is the wire-to-terminal order for the window switches on the driver's door in case you want to make a note The numbers are in very small print next to the terminals on each switch.
Thanks, again...NavyDavy (P.S. Great interior)
Driver's Window
1 - Blue
2 - Blue/Black
3 - Single Red/Blue
4 - Brown
5 - Double Red/Blue
Passenger's Window
1 - Red/Black
2 - Red/White
3 - Double Red/Blue
4 - Brown
5 - Double Red/Blue
Old 09-27-2004, 12:10 PM
DJB DJB is offline
DJB's Avatar
Glad it all worked out Navy Davy.
Ronin - camera's and me are not a good match so I can't really help. I do remember selecting macro mode just before shooting.
Gone and Missed:
Old 09-27-2004, 12:44 PM
sounds good to me... thanks
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-27-2004, 01:33 PM
