Cleaning Anodized Wheels
Okay, so I searched all of the fuch's refinishing discussions and couldn't find the answer to this questions.
What is the best way to clean anodized rims? I just got back my wheels from Harvey Weidman, they are aluminum 944 space saver spares for my 356. He anodized them and they look great.
Harvey recommended soap and water for cleaning to avoid any staining. Though he warned me grease was hard to get off, and there is a little bit of grease on the wheels from the tire mounting. Anyway soap and water didn't cut it. I used a little spit shine and elbow grease with marginal success.
How does everyone else clean their anodized rims? and any success with grease in particular.
Thanks,
Old 11-13-2004, 08:31 PM
schleg79's Avatar
Vaseline. Works like magic. It has completely revived my wheels; removed water stains, re-glossed the oxidized black parts, etc.... Simply rub it on with your fingers and wipe it off with a cloth.
Try a thread search on the topic.
Kevin
78 SC Coupe Silver
79 SC Coupe GP White - sold
Old 11-13-2004, 09:16 PM
Ah, I have read those threads.
Does it clean though, I thought it was just a 're-new' effect.
I am somewhat hesitant to put it on over any dirt/grease though...
Old 11-13-2004, 10:27 PM
Randy Webb's Avatar
use p21s to clean, then the vasoline; do not use the more common wheel cleaners
Old 11-13-2004, 10:55 PM
turbo dreaming
I've been using p21s wheel cleaner on my anodized kinesis rims and it works great.
Princeton Wong
96' 993 Carrera 2...Turbo
As seen on MaydayGarage: http://goo.gl/mGmZB
In Excellence #191: http://goo.gl/BjOsn
Old 11-13-2004, 10:56 PM
911 user
Milu's Avatar
Clean with WD40.
Then, wipe on wipe off vaseline.
The thinnest coat of vaseline is enough to protect the wheel. A thick film of vaseline allows brake dust and grit to stick to the wheel. I'm lazy and just use the WD40, seems to work ok.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 11-14-2004, 12:22 AM
911 user
Milu's Avatar
Be careful with the WD40 as it can also remove the balance weights from your wheel.
Old 11-14-2004, 07:51 AM
Guys, thanks for the feedback.
I'll follow up on the results.
Old 11-14-2004, 11:50 AM
